Custom CSV Report Exports
CMM-Manager is capable of creating customized CSV exports of reports. This allows user to position data in particular columns to create their own unique format. There are multiple steps to effectively creating a custom CSV that are covered below.
Creating a Template
To begin using the custom CSV export feature in CMM-Manager, you must first create a template that defines the data to be exported and its structure. The template is a delimited data file that uses tags to specify data fields. (Tags are explained in detail in the following section.)
Delimited data formats, such as CSV (Comma-Separated Values), TSV (Tab-Separated Values), or other similar formats, separate data values with a specific delimiter (e.g., commas, tabs). For simplicity, we recommend creating the template in Microsoft Excel and saving it as a CSV file if you have Microsoft Office Products. There are other free CSV editors that can be found online that work for this as well.
A custom CSV export template in CMM-manager consists of three primary components: the data row, delimiter, and content. Each component is essential for defining the structure and output of your exported data. These components are described in detail in the following sections.
Tags
Tags in CMM-Manager are placeholders that instruct the software on which data to populate in specific cells of the exported CSV file. Each tag is enclosed within double curly braces, formatted as {{tag_name}}. The following sections provide a comprehensive list of available tags and their corresponding data fields in generated reports.
Header Tags
Header Tags correspond to metadata associated with the entire report collection, such as the unit, date, or runtime. These tags are used to populate data fields that apply globally to the report, regardless of the specific report. For example, a tag like {{Unit}} retrieves the unit used in the whole report. These tags are typically used in templates to construct a header for the custom CSV report.
Tag
Description
ReportName
The name of the overall report
PartName
The set name of the part
PartNo
Part number as specified in the the report properties
Insepctor
Specified operator/inspector
Company
Specified company
Date
Date the report was created
Time
The time at which the report was created
Unit
Unit that the report was made in
CADName
Name of the CAD file used
ProjectFile
Name of the program
PassFail
Whether the overall report passed or failed
ProgramRuntime
How long the program ran
ShrinkFactor
The shrink factor that was applied to the values
ShrinkAppliedTo
String that specifies what the shrink factor was applied to
Customer Data
Customer data can be incorporated into your CSV export by using specific tags in the template. To reference customer data, use the format {{CD.Name}}, where Name is the customer data field identifier. For example, to include a customer data field named SerialNo, enter the tag {{CD.SerialNo}} in the template. During export, this tag will be replaced with the corresponding customer data value. If the specified customer data field does not exist, the cell will remain empty (populated with an empty string).
VB Variables
VB Variables can also be incorporated into your CSV export by using specific tags in the template. To reference a VB Variable use the format {{VB.Name}}, where Name is the VB Variable identifier. For example, to include a VB Variable named StandardDev, enter the tag {{VB.StandardDev}} in the template. During export, this tag will be replaced with the corresponding VB Variable value. If the VB Variable does not exist, the cell will remain empty (populated with an empty string).
VB Variables are runtime only and thus can only be exported by saving the report after a run
Report Header Tags
Report Header Tags pertain to the metadata of reports within the report. Each report has its own header, which contains specific details relevant to that specific collection of report items (e.g., title, feature, subtype). For example, a tag like {{ReportTitle}} retrieves the title of the specific report associated with a data row. These tags allow you to include item-specific metadata in the exported CSV file.
Tag ValueDescription
ReportTitle
Title of the specific report as display in the CMM-Manager report view
Feature1
Name of the first feature in the report
Feature2
name of the second feature in the report (Only for Distance Between, Angle Between, and Symmetry)
TypeType of the first feature, or the type of report if two features
ReportNote
The report note
SubType
"Inner" or "Outer", if applicable
MaxDev
The max deviation of a given set of points (Same as displayed for CMM-Manager report for Profile, Best fit, Form, Cloud to Curve, Cloud, and Cloud to Surface reports)
MinDev
The min deviation of a given set of points (Same as displayed for CMM-Manager report for Profile, Best fit, Form, Cloud to Curve, Cloud, and Cloud to Surface reports)
RMSDev
The RMS deviation of a given set of points (Same as displayed for CMM-Manager report for Profile, Best fit, Form, Cloud to Curve, Cloud, and Cloud to Surface reports)
Report Data Values
Report Data Values represent the specific data associated with individual report items within a report, such as measurements or attributes (e.g., X, Y, Z, Pos). These values are contained within the data rows of a custom CSV report. In the template, tags like {{CharName}} are used to retrieve the name of the report item (e.g., X, Y, Z, Pos) and {{Nom}} can be used the retrieve the nominal value of that report item, if applicable. These tags enable you to populate the exported CSV with precise, item-level data relevant to the specific report being processed.
CharName
Name of the item
Nom
Nominal value of the item
Act
Actual value of the item
DevDeviation of the item
LoTol
Lower tolerance of the item
UpTol
Upper tolerance of the item
OutTol
Out of tolerance of the item (Always displayed as text and only shown if tolerance item is out of tolerance)
Datum1
First datum used for the item calculation
Datum2
Second datum used for the item calculation
Datum3
Third datum used for the item calculation
Data Row
The data row is the core component of a custom CSV export template, as it is repeated for each report item in the exported file. It defines the structure and content of the data rows, which contain the meaningful tolerance values (e.g., measurements or attributes) for each report item. Only one data row can be specified in the template, and it must include the appropriate tags to capture the desired data for all report items. For example, a data row might include tags like {{CharName}} and {{Nom}} to export the name and nominal value of each report item.
Importing the Template
In CMM-Manager, templates are stored and managed on a per-program basis, meaning each template imported into a program is saved within the .cmp or .prg file. This ensures that custom CSV exports function consistently across different computers. To import a template:
  1. Navigate to the Report ribbon bar
  2. Select Custom CSV Settings to open the configuration menu.
  3. Choose the import option and select your CSV template file.
Custom CSV Settings Dialog
The Custom CSV Settings dialog in CMM-Manager allows you to manage and configure templates for custom CSV exports. This section shows the dialog and describes the dialog’s key components and their functions.
Templates List Box
The Templates list box displays all templates imported for CSV exports. Key features include:
  • Template Names : Derived from the file name without the extension (e.g., template.csv appears as template).
  • Uniqueness : Each template must have a unique name. Importing a template with an existing name prompts an overwrite confirmation.
  • Deletion : Select a template and press the Delete key to remove it. Deletion is only allowed if no report uses the template.
Import Button
The Import button opens the File Explorer to select a CSV template file. Upon selection, the Template Import Settings dialog appears, allowing further configuration (see below for details).
Export Button
The Export button, enabled only when a template is selected in the Templates list box, allows you to export the selected template.
  • Opens File Explorer to choose a destination folder and specify a file name.
  • Exports the template exactly as it was imported including the extension.
  • Displays an overwrite warning if the file already exists in the selected folder.
Apply to All Button
The Apply to All button, enabled when a template is selected, applies the selected template to all current reports for CSV exports. It also sets the selected template as the default for new reports.
Apply Default to All Button
The Apply Default to All button resets all current reports to use the default (legacy) CSV export format. It also sets the default format for new reports to the legacy CSV export.
Recent Popup Menu
The Recent popup menu lists recently imported templates, maintained at the computer level for access across different programs. This facilitates quick selection when configuring exports.
Stats Count
The Stats Count section includes:
  • Incremental Checkbox: When checked, the stats count value increments after each program run.
  • Incremental Edit Box: Displays the current stats count. The next exported stats count value will be the displayed v.
The Stats count value can be incorporated into a custom CSV export by using the tag {{StatsCount}} in the template
Template Import Settings Dialog
The Template Import Settings dialog in CMM-Manager is essential for configuring a custom CSV template during import. This dialog opens automatically after selecting a template file via the Import button in the Custom CSV Settings dialog. It allows you to specify the delimiter and data row, with the File Preview aiding in these configurations. Below is an image of the dialog and a description of its key components.
Delimiter
The Delimiter setting defines the character separating values in the CSV template.
  • Use the File Preview window to identify the delimiter (e.g., comma, tab, or semicolon).
  • Select a predefined delimiter or choose Other to input a single custom character.
  • If left blank, the Other delimiter defaults to a comma.
Data Row
The Data Row setting specifies the row in the template that repeats for each tolerance item in the exported CSV.
  • Defaults to the last row of the template.
  • Uses 1-based indexing (e.g., the first row is numbered 1).
  • Reference the bold, blue row numbers in the File Preview to select the correct data row.
File Preview
The File Preview window displays the template as a text document, assisting with configuration. It allows you to:
  • Visually confirm the delimiter separating values.
  • Identify the data row by referencing the bold, blue row numbers displayed to the left of each line.
To import the template, click OK in the Template Import Settings dialog. Once imported, the delimiter and data row settings cannot be modified. To change these settings, you must import a new template with the same name, which will prompt an overwrite of the existing template.
Changing a Report's properties to use a Custom CSV Template
In CMM-Manager, you can specify which template a report uses for CSV exports through the Select CSV Export Template dialog. This section explains how to access and configure this dialog, as well as the behavior of reports across different modes.
Accessing the Select CSV Export Template Dialog
To change the CSV export template for a report, use one of the following methods:
  1. In the report tree, right-click a report and select CSV Export Settings.
  2. In the report tree, right-click a report, select Properties, then click the Settings button next to the CSV checkbox.
Both methods open the Select CSV Export Template dialog which is seen below.
The Select CSV Export Template dialog includes the following options:
  • Use Default CSV Export Checkbox : When checked, the report uses the default (legacy) CSV export format, disabling the Template Combo Box.
  • Template Combo Box : Lists all imported templates. Select the desired template for the report’s CSV export. This option is disabled if the Use Default CSV Export checkbox is selected. If a template is already being used for the report, it will be displayed here.
  • Apply settings to future reports checkbox : When checked and OK is clicked, the selected settings (default export or chosen template) are applied to all new reports created in the program.
Reports vary across Teach, Measure, and Run modes in CMM-Manager; Teach mode reports are copied to Run mode at program start, becoming unique reports.
Example Templates
Included with this knowledge base article are example templates for your reference. You may download, modify, and use these templates to suit your specific requirements.
    • Related Articles
    • Save Report Automatically for use with Discus
      Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document in a format compatible with Discus CMM each time the program is run. Set Report Properties as follows: View the ...
    • Save Report Automatically for use with Prolink QC-CALC Realtime
      Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document in a format compatible with QC-CALC each time the program is run. Set Report Properties as follows: View the ...
    • Save Report Automatically with each Program Run
      Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document each time the program is run. You can save report in the following formats: HTML Microsoft Excel Body-in-White ...
    • Edit Report Header - Image or Text
      It's possible to replace text in the top of Report Header with your own image as shown below. CMM-Manager Report Header From Preferences... CMM-Manager Preferences>Report Choose the Image option and then specify .BMP image as shown here... ...
    • Feature Report
      The Feature report button is used to report the basic attributes of features. Generally, this consists of location, size, and form (including Straightness, Flatness, Circularity, Cylindricity, etc.) Select the Feature button in the Report Tab Basic ...
    CMM-Manager YouTube Channel
