Save Report Automatically with each Program Run
Save Report Automatically for use with Prolink QC-CALC Realtime
Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document in a format compatible with QC-CALC each time the program is run.
Set Report Properties as follows:
  1. View the Report Database
  2. Right Click on Report Name - i.e. Default Report, MyReport1, etc.
  3. Choose Properties...
  4. Check the Save Report Checkbox
  5. Check the QC-CALC File Format
  6. Enter or Browse to Directory and File Name
  7. Click OK to accept
Note - It's possible to save unique file / folder for each Report in Report Database - i.e. you could save .RPT file for Default Report and .PDF for MyReport1, each to a unique file location.
Passing Non-measurement Data to QC-CALC
In addition to the time and date, QC-CALC can save up to 15 Numeric FACTOR values and 15 Text Factors (alpha-numeric) with each inspected part. When you “tag” a part with these types of traceable numbers you can perform analysis on specific situations. For example, you could save the Operator’s Name in Text FACTOR 1 and the Company Name in Text FACTOR 2.
Adding Customized Fields
QC-CALC Settings
Data Source Information
QC-CALC Real-Time reads data from the inspection results file saved by CMM-Manager. This is the normal method of using QC-CALC with CMM-Manager. If for some reason the data source is set incorrectly, data collection will fail. To check, select Tools – Options – Data Collection – Data Source Information, choose ASCII File in the Source Type area, and verify the File Path and Name
File Path and Name
Because QC-CALC is obtaining the inspection results through the use of a file transfer from CMM-Manager, QC-CALC needs to know the location and file name where you configured CMM-Manager to save your data. The default location is;
C:\CMM-Manager\Report\*.csv
The STATS file name can be any name you choose. In fact, you can use a different name for every part routine you write. The default file extension is .CSV and the main file name can be any name you wish. By default, QC-CALC uses the file name as its .QCC file name. If you provide a Part Name in the Report Header discussed above, it overrides the name of the .CSV file discussed here.
Auto-Start QC-CALC Real-Time
If you wish start QC-CALC each time Windows reboots, you can press the Set button in the same Tools – Options – Global – Startup area.
See attached legacy guide from Prolink Software.  Screenshots and filepaths have changed, but the overall process is the same.
    • Related Articles
    • Save Report Automatically for use with Discus
      Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document in a format compatible with Discus CMM each time the program is run. Set Report Properties as follows: View the ...
    • Save Report Automatically with each Program Run
      Once you've taught a program and create Report(s) it is possible to configure CMM-Manager program to automatically save report document each time the program is run. You can save report in the following formats: HTML Microsoft Excel Body-in-White ...
    • Custom CSV Report Exports
      CMM-Manager is capable of creating customized CSV exports of reports. This allows user to position data in particular columns to create their own unique format. There are multiple steps to effectively creating a custom CSV that are covered below. ...
    • Feature Report
      The Feature report button is used to report the basic attributes of features. Generally, this consists of location, size, and form (including Straightness, Flatness, Circularity, Cylindricity, etc.) Select the Feature button in the Report Tab Basic ...
    • Form Graphical Report
      The form graphical report can be deployed to visually understand the form error of a feature. To create a form graphical report of a feature, please measure the desired feature first. It is recommended to increase the point density for the graphical ...
    CMM-Manager YouTube Channel
