USE_ETHERNET 0 // 0 = use serial, 1 = use ethernet
CMM_IPADDRESS 100.0.0.1 // Controller network IP address
CMM_PORT 1234 // Controller network port number
Controller Configuration File: No configuration file (i.e. downl.oad or syspar.asc) is used for the Leitz controller; configuration is stored on the controller.
Error Map: Error Map for Leitz protocol should be located in the controller. If so, no error map file is required. Even so, it is recommended to search for the usual suspects (i.e. comp.dat or comp.asc) and check-in previous client software to see if the software / file-based Error Map was used.
