Hexagon (B&S) - Sharpe2 (DCC)
Sharpe2
Default settings:
Com Port Settings: 4800, E, 7, 1
Info
If the downl.oad file fails to load, try this:
Open C:\ProgramData\QxSoft\CMM-Manager [current version]\Driver\SharpeDriver.ini
Find the line:
DOWNLOAD_NEW 0 // 0 - old method, 1 - new method
Change to:
DOWNLOAD_NEW 1 // 0 - old method, 1 - new method
    • Related Articles
    • Hexagon (B&S) - Sharpe32 (DCC)
      Sharpe32 Default settings: Com Port Settings:4800, E, 7, 1 Configuration File: Downl.oad or Syspar.asc file is required. See the install guide for details on the location and usage of these files. Error Map: Comp.dat or Comp.asc file will likely be ...
    • Hexagon (B&S) - Leitz / Sharpe32z / RC1 (DCC)
      Models: Leitz, Sharpe32z, RC1 Leitz (Com Port) Default settings: Controller Selection: Leitz Com Port Settings: 9600, N, 8, 1 ProbeType - TP6 Leitz (TCP/IP) Default settings: Controller Selection: Leitz TCP/IP: IP address in the range 80.128.0.X ...
    • Hexagon (B&S) - Identify Sharpe32 vs. Leitz controller
      The Sharpe 32, Shrp32z, Leitz protocol controllers can be packaged in a similar unit and not easily distinguished. Here are several ways to identify Sharpe 32 vs. Leitz protocol: 1. Check communication settings in current software Sharpe: COM 1 4800 ...
    • Hexagon (B&S) - Reflex Box / Micro Height 3D (Manual)
      Model: Reflex Box / Micro Height 3D Firmware must be 2.4+ to support pass-through mode for communication to CMM-Manager.
    • Hexagon (B&S) - Man3 (Manual)
      Model: Man3 Box
    CMM-Manager YouTube Channel
