The Sharpe 32, Shrp32z, Leitz protocol controllers can be packaged in a similar unit and not easily distinguished. Here are several ways to identify Sharpe 32 vs. Leitz protocol:
1. Check communication settings in current software
- Sharpe: COM 1 4800 E 7 1 // com interface (port,baud,parity,data,stop)
- Leitz: COM 1 9600 N 8 1 // com interface (port,baud,parity,data,stop)
2. Check for Downl.oad or Syspar configuration file on existing system
- Sharpe: Either Downl.oad or Syspar (older systems) will exist on the PC (see install guide for location)
- Leitz: All config is stored on controller there should be no config file stored on local PC
3. Use Hyperterminal
- Start Hyperterminal, and press Ctrl+ECB.
- If it is Leitz protocol, it should display “Ready”, and further command can be issued, e.g. “TESTSOFT”
4. Check cable connection
- Sharpe Protocol
- dongle on "Servo Key" connector
- RS232 cable on H1J0 (DB9 female)
- RS232 cable on H2J0 for Renishaw PHC 9/10
- Leitz Protocol
- no dongle
- RS232 cable connected to DB9 male connector next to "Servo Key" connector
