There are many things that can affect the final result of a CAD import.
- Methods used to create the original CAD model (ie: surfaces vs. solids)
- Export options from the source CAD program
- Import options in CMM-Manager
This article will offer some suggestions on how to improve the fidelity of the imported model.
How models are imported into CMM-Manager
CMM-Manager uses IGES as its native format. All non-IGES models are converted to IGES before being imported into CMM-Manager.
Direct IGES Import
When importing IGES files, the IGES CAD entities are read directly into CMM-Manager.
Non-IGES Translation / Import
When importing formats other than IGES, the CAD model passes through CAD Converter and is translated into IGES format. This IGES file is then read into CMM-Manager as above. The intermediate IGES file is stored in the 'c:\ProgramData\QxSoft\CMM-Manager xxxx\Design' folder and can be used for other programs rather than converting the file again.
Problem IGES Model Repair / Import
When selecting the IGES file to open, click the Options button and select Pre-Process. This will pass the IGES file through the CAD Converter and attempt repairs.
Click the above link for information about best practices for export from 3rd party CAD systems
CAD Conversion/Import flow
CMM-Manager will display the status of the conversion and/or import on the CMM-Manager Status bar. If problems occur, know where the error occurred may help us better understand the problem.
Loading:
The following status is displayed while the CAD is being imported to CAD Converter.
[xx%] Loading model file...
Saving:
The following status is displayed while the converted CAD IGES file is being saved to a file on the PC.
[xx%] Saving converted file...
Importing:
CMM-Manager will display various progress messages on screen while importing the IGES file as well as the following message on the status bar.
Importing converted file...
Conversion / Import Problems
- If an error occurs during conversion or import, knowing the step that was active at the time will be helpful. Please note the message on the status bar or take a screenshot.
- If the problem occurs during Loading or Saving, please see this article about Troubleshooting CAD Converter Errors.
- If the problem occurs during Importing, please take a screenshot.
- If the system seems to "hang" while importing, check your Chord Height Tolerance settings. (Display Tab | View | Chord Height Tol.) This value should typically be between 0.050 and 0.250 in mm. If it is set considerably lower than this, importing a CAD model may take a very long time.
- If CMM-Manager "crashes" during import, please note the message on the screen which will show the location of any crash dump logs.
In all cases, please send any descriptions of the step at which the error occurs and any screenshots of error messages or status bar messages. If it indicates a crash dump has been created, note the location.
Fixing problem models
CMM-Manager has several options available for each CAD file type which can be modified to fix various issues. These options are available from the Options button on the Import CAD Model dialog which is opened from Import/Export | Import | CAD. Depending on the licensed CAD options you will be presented with a tabbed dialog for with options for each CAD format. With CMM-Manager Standard, the IGES, STEP, and VDA-FS options will always be available.
The most common options that affect fidelity of imported models are:
- Flavor
- SplitPeriodic
- Healing
The first option to try is to change the IGES flavor from the (new) default of 'None' to 'JAMA' and try to import the model again. The option 'None' will open more models cleanly than 'JAMA' so it is recommended you do not leave this set to 'JAMA'.
Flavor must be set to 'None' to properly import colors in CMM-Manager 2022
The second step would be to import the intermediate IGES file from 'c:\ProgramData\QxSoft\CMM-Manager xxxx\Design' using the Pre-Process option which attempts to clean up IGES files directly. This checkbox will only be displayed if the "File Type" IGES is selected in the dropdown.
If this does not work, you can try the other options listed above. Not all options are available for all CAD types. IGES options always affect the conversion.
If none of the above resolve the problem, please send an email to
support@qxcmm.com with a brief description of the problem along with a
helpdesk file, and a screenshot showing the faulty conversion. If possible, attach the original CAD file for diagnosis.
An improved set of default options is included with CMM-Manager 2022. There are two files containing the new options: IGES.txt and STEP.txt. They are available for download from the links below and will work with previous versions of CMM-Manager and CAD Converter. These files should be placed in 'c:\ProgramData\QxSoft\CMM-Manager xxxx\Options', overwriting the original files.
If you click the Defaults button in versions prior to CMM-Manager 2022, the options which were standard in that version will be used and you will have to overwrite the files again.
2022 CAD Option files
To use the improved options for CAD import in versions prior to CMM-Manager 2022, please download the following files and replace the existing files in 'c:\ProgramData\QxSoft\CMM-Manager xxxx\Options'.
2024 Improvements
CMM-Manager / CAD Converter 2024 has several updates with additional options for fixing problem models. These changes are not available in versions before CMM-Manager 2024. Please email
support@qxcmm.com for more information.
