Try launching CMM-Manager and importing the CAD files again.
- If you receive an error message indicating a missing DLL, ie: "The program can't start because CONCRT140.dll is missing from your computer", you will need to manually re-install the Microsoft Visual C++ 2015-2019 Redistributable:
- Download and install the 64-bit redistributable: https://aka.ms/vs/16/release/vc_redist.x64.exe
- Download and install the 32-bit redistributable: https://aka.ms/vs/16/release/vc_redist.x86.exe
- Try launching CMM-Manager and importing the CAD files again.
- If you receive an error message indicating a missing DLL, ie: "The program can't start because api-ms-win-core-path-l1-1-0.dll is missing from your computer", and you are running Windows 7, Windows 7 is no longer supported from CAD Converter 2022 forward. See the warning at the top of this article.
Another issue has been seen where a fatal error occurs creating a dump file after attempting to import a CAD file in CMM-Manager:
Followed by an error indicating CoCreateInstanceFailed (message - "Server execution failed"):
