Nikon - iNexiv / VMZ-R / VMZ-S (DCC)
iNexiv
Nexiv.cfg (C:\iNEXIV\Init)
Hosei.dat (C:\iNEXIV\Init)
Quadra.dat (C:\iNEXIV\Init)
ITFUSBLIBDLL.dll (C:\Program Files\Nikon\iNEXIVT)
Edit Nexiv.cfg to extend Joy-Stick volume limits to allow rack calibration. Modify the following parameter to extend limit (typically X+ direction)
[Stage]
StopLower=
StopUpper=
Error Map files (Quadra and Hosei) must be converted to CMM-Manager format. Send files to your local support team for conversion.
Set DCC Move Acceleration to 125mm/sec/sec if you experience trouble with Vision and Laser AF using the Focus option. Default DCC Acceleration is 250mm/sec/sec, default will be 125mm/sec/sec starting with CMM-Manager version 3.7 SP2.
Attached " iNexiv.zip"  is the baseline machine config for iNexiv / VMA 2520 - Import this file from System > Configuration > Import.
Setup instructions for iNexiv (Newmark) Rotary Indexer - iNexiv Rotary Indexer Setup and Calibration -CMM-Manager Forum - Archives
