CMM-Manager - System Pearl / File Menu
File Menu (System Pearl)
The System Pearl in CMM-Manager is the primary circular application button located in the top-left corner of the workspace. It replaces the traditional File menu from older software layouts, serving as the central hub for essential project management commands.
When you click the Pearl, it opens a dropdown menu where you can perform standard file operations such as creating a new project, opening or saving existing inspection routines, viewing file security settings, and managing print options. It also streamlines software configuration by housing a dedicated Preferences button near the bottom of the menu interface. For maintenance and troubleshooting, selecting Diagnostics within the Pearl menu gives you access to tools like the Log Manager for controlling communication logs, as well as the utility to generate a Help Desk file for technical support.
File and Project Management
Start a New project, Open saved programs or projects, Close the active project, Save your session, or use Save As to save a copy under a new file name. You can also quickly reopen recent work using the Recent Files list.
Printing Options
Access Print, Print Preview, and Print Setup to configure and output graphics views.
File Security
The File Security option under the System Pearl menu in CMM-Manager allows you to view and manage protection settings for the active project or program. It controls three main access rights: View, Modify, and Run permissions.
The View permission determines whether an operator can inspect the parameters of program steps, while Modify permission—which requires View privilege—allows users to edit and update those operations. Run permission specifically controls whether someone can execute the part program on the machine. To prevent unauthorized changes on the shop floor, these permissions can be locked behind a password, which authorized users can later change or remove as needed.
Auto Save Results
The Auto Save Results option, located under the System Pearl menu, is a command available across all CMM-Manager operation modes. Its primary function is to automatically preserve inspection output by saving the measured features, collected data points, and generated tolerance reports from a part program execution directly into a new CMM-Manager project file (.cmp).
When running part programs repeatedly for batch inspection, CMM-Manager records and evaluates measurement data for the active run. With Auto Save Results enabled, the software automatically archives a standalone project file on disk as soon as program execution finishes, eliminating the need for machine operators to manually trigger a save command or enter file details after every single inspection cycle.
This functionality is especially useful in high-volume production and quality assurance workflows. By saving each completed run into its own distinct project file, quality personnel maintain complete data logging and traceability for every inspected part. If a part requires secondary review or audit verification down the line, engineers can open any archived project file to examine the exact feature actuals, re-evaluate tolerances, or reprint detailed reports without needing to remeasure the physical part on the CMM.
Options
  1. Auto Save Run Results: When enabled, CMM-Manager saves a copy of the current project after each run to preserve measurement data.
    1. Directory: Specifies the folder on your PC where the Run Results file will be saved.
    2. File Name: Specifies the desired output file name.
    3. File Conflict and Sequence Rules
      1. Overwrite File: Replaces the previous Run Results file with the latest data after each run.
      2. File + Sequence Number: Appends an incremental number (e.g., ...1, ...2) to the file name to preserve each run as a separate file.
    4. Suffix - Customer Data: Appends the value of a selected Customer Data variable to the end of the output file name.
  2. Auto Save Program Summary: When enabled, a text file is saved containing a summary of the program structure and its timestamp.
  3. Auto Save Tip Summary: When enabled, a text file is saved detailing the tips used in the program.
    1. Directory: Specifies the destination folder for the Program Summary and Tip Summary files.
    2. File Name: Specifies the desired file name for the Program Summary and Tip Summary files.
      1. Overwrite File: Replaces the previous summary file with the latest data after each run.
    4. Show Details: When enabled, the Program Summary includes additional details, such as move and touch commands for each feature measurement.
  4. Save CAD model: By default, Run Results files do not include the associated CAD model to help conserve disk space. Enabling this option forces CMM-Manager to include the CAD model in the saved file.
Project Properties
Selecting Properties... opens a summary window that displays key metadata and administrative information about the active project file.
Specifically, project properties allows you to view:
  1. Project File Version: Displays the CMM-Manager software file version in which the project was created or saved.
  2. CAD File Name: Shows the path and file name of the CAD model associated with or imported into the active project.
  3. Project Revision History: Displays a log of recorded revision changes and modification history for the project over time, if available.
This information helps quality personnel quickly verify project compatibility, confirm associated CAD drawing links, and track revision history across different inspection builds.
Shop Floor Launcher (SFL)
Shop Floor Launcher is an interface environment built specifically to streamline batch production inspection on the shop floor. It allows quality teams to operate the software in two main modes depending on user roles: Editor Mode and Operator Mode. In Editor Mode, engineers and programmers can build customized, push-button screens with specific visual layouts, program execution buttons, and operator prompts. Operator Mode then presents this simplified interface to shop-floor operators so they can run inspection routines with a single click while protecting the underlying code from accidental edits.
Please see following knowledge base articles for configuring and deploying SFL:
  1. CMM-Manager | Shop Floor Launcher (SFL)
  2. CMM-Manager | Batch Run and Palletization using Shop Floor Launcher
Log Manager
Log Manager under Diagnostics is a diagnostic utility designed to toggle hardware communication logging on and off for your CMM, Rotary, and Vision drivers. It is primarily used when troubleshooting machine communication issues and working with technical support to analyze controller traffic.
Information on how to capture the communication log can be round here - CMM-Manager Communication Log
It is recommended to keep this option disabled unless needed, as log files can consume a significant amount of hard drive space if logging is enabled for an extended period.
Monitoring Settings
This function, available under Diagnostics, can be used to enable or disable CMM-Manager’s event logging, as well as track the number of triggers for each probe assembly to help estimate the lifespan of the triggering module.
Create Help Desk File
The Create Help Desk File utility, located under the Diagnostics section of the System Pearl menu, provides a quick, one-click method for exporting your complete CMM-Manager environment. Selecting this option gathers your entire machine configuration, active probe assemblies, current part program, and measurement run results, compressing them together into a single zip file. By default, the software generates a zip filename containing the CMM-Manager version number and date, though you can rename it to something more descriptive before saving it to a location on your computer.
This tool serves two primary purposes in your inspection workflow. If you ever encounter machine or programming issues, sending this file to QxSoft technical support allows engineers to evaluate and diagnose the problem using your exact environment setup. Additionally, it acts as a reliable configuration backup. Creating a Help Desk file when your CMM is running properly and storing it in a secure location gives you a baseline snapshot that can be used to restore your entire CMM-Manager configuration if your computer or hard drive ever fails.
Depending on your CMM controller, additional files may need to be extracted along with the Help Desk File to ensure a complete system backup. Please refer to the following article for more details: Backup Controller Related Files
Preferences
The Preferences button, located near the bottom of the System Pearl dropdown menu, serves as the central control panel for configuring all global application settings and user options in CMM-Manager.
In the Preferences dialog box, settings are categorized by functional module within a left-hand navigation panel. Clicking a main module—such as General, CAD Measure, Manual Measure, Scan, or Vision—expands its related sub-topics. Under the General section, you can adjust default behavior for options such as auto feature measurement, automatic file saving, DCC motion, path creation rules, probe assembly settings, tip calibration, reporting formatting, and user interface options. The interface automatically filters this view to display only the features supported by your active software license.
At the bottom of the Preferences window, management controls allow you to track or reset changes:
  1. Restore Defaults: Restores the default values for whichever specific preference panel is currently displayed.
  2. Restore All Defaults: Resets all preferences across every category back to software default values.
  3. View Changes: Opens a list in an XML-compatible browser (such as Edge or Chrome) showing every setting that currently differs from factory defaults.
  4. OK: Applies and saves your configured options to close the dialog.
It is highly recommended to keep Preferences at their default settings unless adjustments are necessary, as modifying settings incorrectly may adversely affect your environment. Please consult the QxSoft Support team (support@qxcmm.com) for assistance with any modifications.
