Instructions for exporting the machine configurations for several controllers are found below.
- DEVA
- LK / Metris / Nikon (CMM Controllers only)
- Renishaw
DEVA
These instructions apply to all current deva manual and DCC controller configurations.
Back up the DEVA controller configuration:
- From the Windows Start Menu, select DevaCmm Tools | Deva Config Editor
Deva Config Editor- Click the Backup button to open the Save As dialog.
Config path and filename- Enter a path and filename, then click [Save].
- Close the Deva Config Editor
- Copy this file to a safe backup location for disaster recovery, or send to support@qxcmm.com if requested for support purposes.
LK / Metris / Nikon
These controllers were branded based on current ownership of the LK brand. They would include the CUPE, Micron Drive, 2000, 4000, 100, 200, and 300 controllers.
Back up the LK controller configuration:
- Browse to c:\lk\appdata
- copy, or create a zip of the entire contents of the c:\lk\appdata\CMMCFG and c:\lk\appdata\Errc folders.
- Copy these files to a safe backup location for disaster recovery, or send to support@qxcmm.com if requested for support purposes.
Renishaw
These instructions cover the Renishaw UCC line of controllers
Beginning with UCC Suite 5.7, all data files are stored in c:\ProgramData. The remainder of the path is the same. The ProgramData folder is typically hidden by default by Microsoft. You must either "Show Hidden Files", or type c:\ProgramData in the address bar to access the directory. Browsing works normally from that point on.
Back up the machine configuration:
- Copy, or create a .zip of the following directory and store to a backup location:
- c:\Program Files (x86)\Renishaw\UCC\Machine\
- Note: 32 bit versions of Windows will not use the (x86) directory, instead the files are located at c:\Program Files\Renishaw\UCC\Machine\
Back up the environments:
First, ensure that UCCServer launches in advanced mode with the commands page available.
If the highlighted options below are not available, proceed with the following steps to enable them.
- Close UCCServer
- Right-click on the Desktop icon and select Properties
- Append -advanced -command to the end of the Target file location
- Select the Apply button and OK to close the dialog
- Open UCCServer
- Select the Environment tab
- Right-click on the environment you wish to export (the active one) and select 'Export'
- Browse to your desired file path and name the file accordingly
- Save the *.mzp file to a backup location
- In a few rare cases, customers may have more than one environment that they switch between. If that is the case, right-click and save any other custom environments you may use.
