Creating a Program Offline
Overview:
The offline programming capability will enable the user to create inspection programs outside of CMM-Manager installed on a CMM workstation. This reduces the CMM downtime significantly caused by the online programming process, which could be several hours depending on the complexity. Also, the user is not tied to the physical location of the CMM for programming, thus he/she can work on a new program from the comfort of his/her office desk or even home (working remotely).
Requirements:
  1. Your online CMM-Manager is fully configured and functioning.
  2. Offline CMM-Manager is installed on a laptop or a PC not connected to a CMM.
  3. The software version of your offline seat is the same or older than the online version (since a program is not backward compatible).
  4. A CAD model is recommended for the part to be offline programmed, but is not required.  Define Manual/DCC can be used in conjunction with a print.
Obtaining an Offline CMM-Manager License:
The offline seat is generally 50% of the cost compared to the online equivalent. Please contact QxSoft or your reseller to obtain the exact pricing. A 30-day trial license can be requested from the link below if you would like to test the offline programming before purchasing a license.
Configuring Your Offline CMM-Manager:
It is crucial that the offline program is created in the same environment as your CMM since the mismatch may lead to the unnecessary program modification, potential collisions, and other time-consuming steps. The easiest way to match the configuration on 2 seats is to generate a help desk file from your online CMM-Manager then import it in the offline version. This will transfer machine volume, probe head type, probe assemblies, tips, and other settings all together.
First, create a help desk file from your online CMM-Manager by following the instructions from the link below. Once the file is generated, please transfer it to your offline PC.
Next, please open the offline CMM-Manager then import the help desk file via the Import button under the System tab. Restart the software for the new configuration to take effect.
At this point, your offline seat is ready for programming. Please re-generate then re-import the help desk file if there is any change on your online CMM-Manager environment (machine configuration, new probe assembly, etc.)
Programming Offline - Importing and Placing CAD Model:
Once you have created a new project, please import the CAD model of the part that you would like to create a program (Import/Export => CAD in the Ribbon Bar). If the CAD model did not import correctly, please use the link below for troubleshooting. If necessary, change the location of the CAD reference frame at this time to match your intended initial alignment.
Since the actual part cannot be measured to perform an alignment, you must use Place CAD function to set the model to approximate location and orientation to match real part setup on the CMM. Please pay extra attention to the part orientation as it will affect tip angle selection.
To move the model, please click the Drag button in the Translate group then click-then-drag it to the desired location. Clicking the Center button will shift the CAD to the center of the volume on the table. Drop to Table button will retain current X & Y positions in the Machine Coordinate System but changes the Z position to set it on a table. The Drag function works better if it is done in direct views and is normal to the screen view (right-click on the Display Window then select Top, Bottom, Left, Right, Front, or Back).
Buttons in the Rotate group are used to manipulate the orientation. Please note that these functions are only allowed if you are in direct views and is normal to the screen view.
Once the model is properly located, please click the OK button to confirm the placement. The software will snap the part coordinate system (PCS) to the current CAD reference frame as if you performed an alignment.
Programming Offline - Sync Part Ref Frame:
Place CAD function will establish the part reference frame; however, this is not added to the program and temporary. At this time, we must insert Sync Part Ref Frame operation to the beginning of the program to ensure the consistent reference frame location.
Sync Part Ref Frame function is located in Import/Export tab in the Ribbon Bar. This operation must be added prior to proceeding with any alignment or measurement steps.
Programming Offline - Alignment:
Although the software will not be able to drive the CMM and measure, the user can still add the alignment scheme into the program. These alignment steps must yield the part coordinate system created from Sync Part Ref Frame command.
Some of the common alignment schemes and suggested steps for the offline programming is listed below.
Manual Alignment using Canned Alignment - Click on the desired canned alignment method in the Ribbon bar. Unlike an online environment, the software will not prompt you to collect measurements. Instead, the alignment toolbox will appear immediately to define the axis orientation.
Manual Alignment using Traditional Alignment - Generally, this is accomplished using the joystick mode to measure features (blue icons under Features tab); however, they are not available in the offline environment.
Instead, please use CAD Teach 2D/3D/Slot (joystick) to create feature measurement commands for level, align, and set origin operations.
DCC Alignment using Traditional Alignment - The steps will be the same for online and offline except that Verify function for measure features commands will be grayed out. Please do not forget to add Sync CAD at the end of the DCC alignment if you are performing it after the manual alignment.
Advanced Alignment (CAD, Free Position, etc.) - Most alignment commands in the Advanced group can be added to your offline program.
Programming Offline - Feature Measurement & Reporting:
Once the alignment steps are programmed, the user can proceed with feature measurements and reporting. These will act exactly like the online CMM-Manager aside from the Verify function is not available for feature measurements. Therefore, use Simulate button to check the probe path instead.
Porting the Program Online:
Transfer the completed offline program to the CMM workstation then set the part on the CMM. Ensure that the part location and orientation on the physical machine is similar to how it appears in the program. Once CMM-Manager is online with the controller, please perform Align Part function to synchronize the program created offline to the real environment (see the link below for the instruction). This must be done even if your program contains a manual alignment.
Once Align Part is performed, your program is ready for the test run. Please execute the program at a slow speed to confirm that it does not cause any collision and output the intended result.
