This depends primarily on your part tolerances, production throughput, and shop-floor environment. In many manufacturing operations, routine tip calibration typically occurs anywhere from once per day or at the start of every shift to once per week. High-precision applications with tight tolerances or high-volume automated runs demand daily or shift-level qualification, while general inspection tasks under stable laboratory conditions often perform well on a weekly schedule. As a guiding metrology rule, you should calibrate at an interval that ensures consistent confidence in your inspection results.
Regardless of your regular calendar schedule, immediate tip qualification is required whenever specific physical or environmental triggers take place. You must recalibrate immediately following any probe collision or machine crash, even if no visible mechanical damage is apparent. Recalibration is also mandatory whenever you assemble a new stylus configuration, loosen or replace hardware components, change extension bars, or suspect that the initial probe state is uncertain. Furthermore, substantial shop-floor temperature shifts, changes to your programmed touch speeds, or unexplained measurement drift during interim checks on a known artifact necessitate an immediate requalification.
To establish a tailored schedule, start by calibrating daily and logging the resulting tip diameters, center offsets, and form errors in a historical tracking record. If the data remains statistically stable across weeks of operation without drift, you can safely extend the interval to semi-weekly or weekly. However, if an interim check on a certified master part or reference artifact reveals out-of-tolerance deviations, revert to more frequent calibrations immediately.
What is Effective Tip Diameter? Why is it Smaller Than the Nominal Diameter?
During tip calibration, the CMM probes a certified reference sphere of known diameter across multiple directions to capture contact points from the center of the stylus ball. The software calculates a best-fit sphere through these center coordinates and subtracts the certified sphere diameter from the measured sphere diameter to establish the effective tip diameter. This calculated value serves as the functional size that the software uses for probe radius compensation when measuring workpiece features.
The calibrated effective diameter is virtually always smaller than the stylus ball's actual physical dimension because it mathematically compensates for probe pre-travel and stylus bending. When a touch-trigger probe contacts a surface, the stylus stem deflects slightly like a cantilever and the internal mechanism moves against spring tension before reaching the threshold that latches the machine coordinates. Because the machine scales record position at the moment the trigger occurs rather than at the exact instant of first physical contact, the probe travels a minute distance into the surface.
During calibration, this displacement causes the apparent distance between opposite probing points on the reference sphere to be slightly undersized compared to an unyielding contact. When the certified reference diameter is subtracted from this measured sphere, the resulting calculated stylus diameter absorbs that deflection deficit. By storing this reduced "effective" diameter instead of the nominal ball size, the CMM automatically cancels out pre-travel during measurement routines, ensuring that external and internal features of size are reported accurately.
When a probe measures a certified reference sphere during tip calibration, the software calculates a best-fit sphere through the collected touch points. Form error—also called form deviation—is the span between the maximum and minimum radial distances of those measured contact points relative to the best-fit center. It represents the apparent roundness or sphericity of the sphere as seen by that specific stylus configuration. Rather than measuring a defect in the reference artifact itself, form error quantifies the variation and repeatability of the probing system across different approach vectors.
In a properly functioning setup, form error is driven by probe lobing, which is the inherent three-lobed pre-travel variation of standard mechanical touch-trigger mechanisms as they trip in different directions. It also reflects stylus shank bending under trigger force, minor sphericity limits of the ruby ball, machine vibrations, and structural compliance across extension bars. High or sudden increases in form error usually point to physical issues such as dust or oil on the reference sphere or stylus ball, loose stylus threads, a worn or chipped ruby ball, or an unstable mounting joint.
For standard, well-calibrated and maintained bridge CMMs equipped with short, rigid styli, an acceptable form error typically falls within a few micrometers—commonly between 0.001 mm and 0.003 mm (1 to 3 µm). Longer styli, complex star configurations, or heavy knuckle extensions experience increased mechanical flex, where form errors up to 0.005 mm (5 µm) may be normal and acceptable. As a general rule of thumb, your calibration form error should consume no more than a small fraction of your tightest part tolerance.
If a tip returns an unacceptable form error, start by thoroughly wiping both the reference sphere and the stylus ball with a lint-free cloth and solvent to eliminate debris. Check that every shank joint and extension is snugly tightened with the appropriate stylus tool, as loose joints are a frequent culprit. Finally, verify that the qualification speed matches your part measurement speed and re-run the calibration cycle to confirm repeatability.
Can I Inspect with an Uncalibrated Tip?
Using an uncalibrated probe tip for part inspection is strongly not recommended. Measuring with an uncalibrated tip yields inaccurate measurement results of unknown magnitude. In CMM-Manager, you can define and select uncalibrated tips while creating or editing an inspection program offline, but the software will not permit automated Direct Computer Control (DCC) inspection routines to execute with uncalibrated tips.
A coordinate measuring machine does not directly record the contact surface of a workpiece; it records the three-dimensional center coordinates of the stylus ball. To calculate the true surface point, the metrology software applies probe radius compensation along the contact vector. Without qualification on a certified reference artifact, the software lacks the calibrated effective tip diameter required to compensate for physical ball size, pre-travel displacement, and stylus shank bending. Any error in tip size transfers directly and additively into all measured features of size, causing internal diameters to measure undersized and external dimensions to measure oversized.
Furthermore, an uncalibrated tip lacks verified three-dimensional center offset vectors relative to the machine reference tip. When inspecting features across multiple probe head angles, star styli, or different probe assemblies, uncalibrated offsets introduce substantial positional shifts and location errors between features measured with different orientations. Ensuring every tip is qualified guarantees that the machine's scales, probe compensation, and multi-orientation offsets align to deliver valid, traceable inspection data.
Alternatively, reference tip calibration and subsequent tip calibrations can be initiated using the icons under the Probe tab in the Ribbon Bar.
