Point collection in CMM-Manager begins as a recorded machine position when the probe triggers. This machine position as recorded and shown in the DRO is not the actual surface point but the center of the tip itself.
The direction used for this compensation is determined by the programmed probe vector, and the size of the compensation is based on the calibrated probe radius.
When the probe vector accurately represents the surface normal, the resulting point is correctly compensated. When the vector is incorrect, the point is moved in the wrong direction, introducing what is commonly called cosine error.
Understanding this relationship is critical when measuring angled surfaces, freeform geometry, bores, slots, and imported CAD features.
When a touch-trigger probe contacts a surface, the CMM records the machine position at the instant the probe triggers. At that moment, the center of the stylus ball is still located one stylus radius away from the actual part surface. This recorded position is not yet the final measured point on the part surface. The software must account for the size of the stylus tip and the direction from which the point was taken. After probe qualification, the software establishes the relationship between that trigger position and the effective tip geometry. The final measured point is then calculated using the qualified probe geometry and the hit vector (direction). CMM-Manager uses the probe vector to determine the direction of probe compensation. If the compensation direction differs from the true surface normal, the calculated point will not be located at the true surface contact location.
A probe vector defines the direction from which the probe approaches the surface.
In CMM-Manager this is typically represented as:
I, J, K
where:
The vector is always normalized:
I² + J² + K² = 1
Examples:
| Vector | Direction |
| 1,0,0 | +X |
| -1,0,0 | -X |
| 0,1,0 | +Y |
0,-1,0 | -Y |
| 0,0,1 | +Z |
| 0,0,-1 | -Z |
A vector should ideally match the local surface normal of the feature being measured.
Many users think the purpose of the vector is simply to tell the machine which direction to move. While true, it is only part of the story.
The software assumes the stylus contacted the part directly opposite the approach direction. If the vector is correct, the compensation lands exactly on the true surface. If the vector is incorrect however, then the applied compensation shifts the point to the wrong location.
Cosine error is a measurement error that comes from the angular misalignment between the approach vector and the surface normal. This error arises during when the stylus contacts the surface at a non-perpendicular angle, causing the system to record a surface point shifted from the actual contact location. Cosine error occurs whenever the programmed vector differs from the actual surface normal.
The issue is not always that the machine touched the wrong place, but that the point can be compensated in the wrong direction.
Consider a flat surface whose true normal is:
0, 0, 1
But the hit is programmed using:
0.1736, 0, 0.9848
which is tilted 10° from the surface normal.
The probe contacts the part correctly.
However, CMM-Manager now applies radius compensation along a direction that is tilted by 10°.
The resulting compensated point will be offset from its true location.
As the angular error increases:
Imagine a 5 mm stylus ball touching a flat surface.
O
Surface
Compensation is applied straight down along the surface normal.
Result:
✅ Correct point location
O
Surface
Compensation is applied at an angle.
Result:
❌ Point shifts sideways
❌ Calculated surface location becomes incorrect
A common mistake is probing an angled face using:
0,0,1
simply because the surface generally points upward.
If the surface is actually tilted by 10°, the compensated point will be shifted.
Instead, use the actual surface normal from:
After an alignment update, vectors stored in older routines may no longer correspond to the actual surface orientation.
Users should verify hit vectors whenever:
Manual estimation and freehand entry of IJK values can introduce small directional errors.
Whenever possible:
On cylinders, spheres, and freeform surfaces, the surface normal changes continuously.
Using a single fixed vector across multiple points can introduce compensation errors.
The best practice is to let CMM-Manager calculate the surface normal from CAD at each hit location whenever possible.
To minimize compensation-related errors:
When CAD is available, allow CMM-Manager to derive vectors directly from model geometry.
Approach perpendicular to the target feature whenever physically possible.
Always check the displayed IJK values for:
Long styli increase sensitivity to vector errors and bending effects.
Use the shortest practical stylus assembly.
Whenever probe orientations or extensions change, perform proper qualification to ensure compensation values remain accurate.
When a feature is measured directly, probe compensation is applied based on the feature instead of the individual point vectors.
Incorrect vectors can tilt a measured plane or shift its location.
Cosine error can affect:
This error becomes more significant when measuring angled bores.
Improper compensation may distort:
Position, profile, perpendicularity, and angularity can all be affected because they depend on accurate point locations.
-Probe compensation and cosine error are fundamentally linked.
-A touch-trigger probe measures the position of the stylus center when contact occurs. CMM-Manager then uses the programmed probe vector to shift that trigger point by the stylus radius and calculate the actual surface point.
-For the most accurate compensation direction, the probe vector needs to match the true surface normal.
-When the probe vector does not match the surface normal, compensation occurs in the wrong direction, shifting the point away from its true location. This shifted point becomes the basis for all subsequent feature calculations, potentially affecting dimensions, locations, orientations, and GD&T results throughout the inspection routine.
-In practical terms, the accuracy of the compensated point is only as good as the tip calibration and probe vector used to calculate it.
