The Ribbon Bar is the main graphical user interface element located at the top of the workspace that provides access to nearly all software commands, measurement tools, and system controls. It organizes complex metrology and programming tasks into intuitive, categorized sections.
This provides access to project file commands (New, Open, Save, Print), project Properties, File Security, Auto Save Results, Diagnostics, and software Preferences.
The Quick Access Toolbar is positioned next to System Pearl and holds a customizable set of frequently used shortcut tools (such as New, Open, Save, and Simulate/Verify Path) that remain visible regardless of which tab is active.
Apple and running man icons near System Pearl control how the software processes measurement actions and whether operations are recorded into an inspection program. These two toggle can be used to select one of three operation modes.
Teach-Off Mode is the default quick-inspection environment in CMM-Manager, active when neither operation mode button is highlighted in the Ribbon Tab Header. You can easily recognize it because the 3D graphics display window changes to a gray background. It is intended for walk-up measurement tasks such as spot checks, machine tool setups, or rapid dimensioning, where measurement steps are evaluated immediately but are not saved into the Program Database for future playback.
Teach-On Mode is activated by selecting the Teach button—represented by a green apple icon in the Ribbon Tab Header—which turns the graphics display background blue. This mode serves as the primary part-programming environment. As you perform inspection steps, set up alignments, or construct geometry, CMM-Manager automatically records every operation and parameter into the Program Database, creating a reusable inspection routine without requiring manual text editing.
Run Mode is engaged by clicking the Run button—marked by a blue running person icon—or by executing any program run command, which changes the 3D graphics background to green. It provides a streamlined environment for running previously taught routines repeatedly during batch inspection. Data collected during execution is stored in the active run results database, keeping execution records distinct from the program creation setup.
Ribbon Tabs
Ribbon Tabs divide software commands and functionalities by workflow category. Below is list of available tabs:
- Alignment Tab: Contains tools to create, modify, save, translate, rotate, and recall part alignments and reference frames (such as 3-2-1 alignment, CAD alignment, and Bestfit alignments).
- Features Tab: Used to teach, auto-measure, construct, and edit 2D and 3D geometric features (including points, lines, circles, planes, cylinders, cones, spheres, point clouds, hole patterns, and slots).
- Report Tab: Houses commands for generating feature reports, applying GD&T geometric tolerances (such as position, profile, orientation, and runout), performing CAD comparison analysis, and configuring report export settings for formats like PDF, Excel, CSV, and HTML.
- Program Tab: Organizes inspection program management tools, including batch/partial execution runs, program simulation, VBScripting, program branching (loops, IF statements, operator prompts), and Operation Planner.
- Probe Tab: Manages probe hardware configurations, probe assembly definitions, probe tip calibration (establishing reference tips, single or multiple tip calibration), stylus change rack setups, and tip management.
- Import/Export Tab: Handles importing external CAD models (such as STEP, IGES, DXF), CAD points, and IQCAD files, as well as exporting raw hit data, actual feature geometries, and managing CAD reference frames (Note: this tab is excluded in "Lite" versions).
- System Tab: Controls machine connection states (toggling Joystick/DCC modes, Connect/Disconnect, Home Axes, Go To, Abort CMM), hardware driver setups, and system calibration/verification utilities (such as B89 tests, ISO 10360 probing/size evaluation, and Error Map creation).
- Display Tab: Controls the 3D graphical workspace environment, including viewport layouts (tiling and splitting views), zoom and orientation controls, toggling the visibility of CAD models, features, probe assemblies, and surface colors.
- Graphical Report Tab: Provides visual annotation tools to create graphical inspection reports, place text boxes and callouts, show magnified feature deviations on CAD images, and organize screenshot-style report layouts.
Additionally, following tabs will be available depending on your hardware & software configurations:
- Scan Tab (Requires Scan License): Unlocks commands dedicated to analog scanning.
- Vision Tab (Requires Vision License): Provides video metrology tools for camera-based CMM systems, including edge-detection tools, illumination light controls, and live video overlays.
- Gear Tab (Requires Gear License): Provides specialized gear metrology capabilities, including gear reference frame creation, gear probe tip calibration, and automated gear inspection checks (such as lead, profile, pitch/spacing, runout, and topography evaluations).
Ribbon Groups
The Ribbon Groups breakdown each tab's commands into targeted sub-categories. For example, the Features tab is organized into groups like Teach, Auto Feature, CAD Teach, and Construct Feature, while the Report tab includes groups like Basic Reporting, GD&T, CAD Comparison, and Settings.
The ? icon located in the top-right corner of the CMM-Manager screen on the Ribbon Bar is the CMM-Manager Help button. Clicking the ? icon launches the full CMM-Manager Help file, allowing you to browse topics using the Table of Contents, search the index, or perform keyword searches to find instructions for software commands and features.
The i icon located at the top-right corner of the CMM-Manager screen, right next to the ? Help button and the Layout menu, is the About CMM-Manager button. Clicking this button opens the About CMM-Manager dialog window, which provides key software, licensing, and legal details about your installation.
- Software Version & Build: Displays the exact version title, build number, and build date of your CMM-Manager application.
- License Details: Shows your active license code and license type (such as DCC Full Version, Trial Copy, etc.)
- Company & Copyright Information: Displays QxSoft, LLC copyright notices and a direct link to the QxSoft website.
- Legal Agreements: Provides links to open the QxSoft Software License Agreement along with third-party software notices and licenses.
Inside the About dialog, there is also a System Info... button. Clicking this button opens a secondary window displaying your computer's graphics hardware and operating system parameters.
The Layout Menu is a dropdown control located at the top right of the workspace screen, right beside the Help (?) and About (i) buttons. Its main purpose is to customize, organize, and manage your graphical workspace environment.
The following are some common tasks that can be performed using this menu:
- Show or Hide Interface Windows: You can toggle the visibility of workspace components by checking or unchecking them in the menu list. If you accidentally close a window, you can quickly recover it here.
- Database Tabs: Feature Database, Report Database, and Program Database.
- System & Tool Windows: Digital Readout (DRO Window), Status Bar Window, View Tools Window, and the Watch Window.
- Vision Inspection Windows: Image Window and Lighting Controls (used for vision metrology systems).
- Reset Windows to Factory Defaults: Selecting Reset Windows instantly restores all floating, docked, or resized windows back to their standard factory positions and default sizes.
- Change Interface Color Themes: Under the Color sub-menu, you can switch the overall software color scheme between four predefined visual themes: Blue, Black, Silver, and Aqua.
- Update Background Color Gradient: Allows you to change the background color gradient in CMM-Manager. You can choose between the lighter gradient (the default in newer versions of CMM-Manager) and the darker gradient (which resembles the appearance of legacy versions).
- Save Custom Layouts: Selecting Save allows you to save your current screen arrangement—including window positions, pinned/unpinned tabs, and toolbar setups—under a custom layout name or export it as an XML file. This is ideal if different operators or inspection tasks require unique screen setups.
- Load Saved Layouts: Selecting Load lets you quickly recall any previously saved layout preset, import layout XML files, or reset the interface back to the software's Default Layout.
