Plane Measurement - Touch
CMM-Manager supports Plane measurement by using touches or scanning.  Multiple methods are available for each, depending on the CMM probing hardware.
Creating a Touch Inspection
Selecting 3-Axis Touches or Head Touches
Depending on the hardware, you may choose to use traditional 3-Axis Touches or Head Touches.  The type of touches to use should be selected before creating the inspection.  Instructions on how to choose the appropriate touch type can be found in Choosing 3-Axis or Head Touches.
Points in a Grid Pattern
Probing Support: PH10 (TP / SP25), PH20, REVO (RSP2 / RSP3)
  1. Define or select a plane from CAD to be measured.
  2. Touch type is determined by the settings in the Path Planning frame.  See Choosing 3-Axis or Head Touches.
  3. Points will be added automatically based on the user settings for the controls for Range, Target Point # and Margin.  The default method is to attempt to create points at the intervals requested by Target Point # based on the settings for Range and Margin.  Points will not be added where no surface exists (a hole).
Be sure to click Create Path to apply your settings.
Points Along the Edge
    3. Points will be added automatically along the edge of the plane by selecting Along Edge and adjusting the edge offset using Margin.  The number of loops and the point spacing may also be specified.
    Manually Picked Points
      3. Points which were created automatically may be adjusted, or points may be added manually by using the tools available on the Points Tab.  Points may be entered manually by using the Keyin Point button or selected directly from CAD by using the Add Pick tool.
      4. It is possible to create a path using only points selected by the programmer.
        1. Use Select All to select all the points in the dialog.
        2. Use Delete Selected to remove all of the points.
        3. Use either Pick Points or Keyin Points to enter the desired points for the inspection.
      Circular Inspection Path
      Probing Support: PH20, REVO (RSP2)
        Alert
        The Circular Inspection Path is available only for PH20 and REVO probe heads.
        1. The Circular Inspection Path can only use Head Touches since it utilizes Fixed Quill motion.
        2. The Use 5-Axis Commands checkbox is selected by default.  If the Rectangular path option is selected, select the circular path option instead.
        1. Specify the number of points desired by using the Target Point # box.  Adjust the desired circle path start and end angles as well as size by selecting Range Adjust and dragging the circle ends and size.  The touch path will be executed as a Fixed Quill path.
        NotesAlert
        It is not practical to Move Points or Pick Points on the Points Tab since this is a Fixed Quill measurement and all points must be on the arc.  Points that are not on the surface, due to a hole for instance, will be automatically removed by path planning.  It is still possible to remove points by using Select and Delete Select from the Points Tab, however.
