Choosing 3-Axis Touches
Probing Support: PH10 (TP / SP25), PH20, REVO (RSP2 / RSP3)
3-Axis touches are the traditional method of collecting touch data. This method is supported by all probe types.
- If you are using a "PH10 style" automatic-indexing head, you will be presented with only the standard (non-5-axis) Path Planning options.
- If you are using a PH20 or REVO, uncheck the Use 5-axis Commands checkbox on the Measurement Tab of the inspection dialog after defining or selecting the plane from CAD. This option will not be displayed if you do not have a PH20 or REVO probe head.
- All touches will be executed using 3-axis motion.
Choosing Head Touches
Probing Support: PH20, REVO (RSP2)
Head touches are only supported by a PH20 or REVO probe head.
- The Use 5-Axis Commands checkbox is selected by default.
- For Points in a Grid Pattern, Points Along the Edge, or Manually Picked or Edited Points, make sure the Rectangular option is selected.
For Rectangular paths, the Incidence Angle is the probe angle between the planar or immediate local point on the surface and the probe. In the case of a Z axis (XY plane) surface, the A angle would be A60 in this example. The incidence angle is limited by both allowable Renishaw probing limits for the probe type as well as collision detection. For example, I may be able technically to request an incidence angle of 3 degrees. But collision detection may override this noting that at this angle, the probe head itself may collide with the plane surface.
- For Circular Inspection Path, make sure the Circular option is selected.
For circular paths, the Incidence Angle is the probe angle between the plane normal axis and the probe. For circular paths, the incidence angle cannot be specified. The incidence angle will be calculated based on the size of the circular path that is defined. The incidence angle, and therefore the size of the circular path, is limited by the allowable Renishaw probing limits for the probe type, the size of the planar surface, as well as collision detection.
