CMM-Manager supports two touch types, as well as two special methods of acquiring touches using a combination of
moves and a basic
Head Touch.
- Basic Touches
- 3-axis: CMM XYZ motion only
- Head Touch: Head motion only (PH20/REVO)
- Special Methods
- Fixed Quill: Head motion + limited CMM XYZ motion + Head Touches (PH20/REVO)
- 5-Axis: CMM XYZ + Head motion + Head Touches (PH20/REVO)
3-Axis Touch
Probing Support: PH10 (TP / SP25), PH20, REVO (RSP2 / RSP3)
3-axis touches use only CMM XYZ axis motion to take the touch. This is the traditional method of taking touches. With a 3-axis touch, the proper probe angle is selected, the tip is placed at a position normal to the feature (point) vector at the specified approach distance from the surface where the touch is to be taken, and the CMM moves along the feature (point) vector and takes a touch.
This is much less efficient than a Head Touch since the mass of the entire CMM frame must be moved to take the touch.
Head Touch
Probing Support: PH20, REVO (RSP2)
A Head Touch uses only head motion to take a touch. The CMM XYZ and/or the head is used to position the tip at the requested approach distance. This position is at a slight angle so as the tip "rotates" to take the touch, the touch itself is at the correct position. A Head Touch uses only head motion to quickly "tap" the surface and acquire the point. This motion may be A axis only as shown here, B axis, or A and B depending on the orientation of the feature.
This is much more efficient than 3-axis touches since only the mass of the head is being moved to take the touch.
Fixed Quill
Fixed Quill touches are used to measure circular features where the probe assembly can be placed along the vector normal of the feature. The probe head's center of rotation is centered on the circular feature, normal to the feature axis. Using only head motion, the tip is positioned, and a Head Touch is used to collect the points. The only CMM motion may be to move the probe along the feature axis to measure at different depths. This type of touch is valid for circular features only such as circle, cylinder, and cone.
5-Axis
5-Axis touches use the head and CMM axes to position the probe and take a touch. Unlike Fixed Quill, all three CMM axes may be used, and the head does not remain centered on the feature. The touches are taken using a Head Touch.
