3D Cloud Measurement - Touch
CMM-Manager supports 3D Cloud measurement by using touches or scanning.  Multiple methods are available for each, depending on the CMM probing hardware.
Alert
Points collected for Cloud inspection are almost always collected with Probe Comp off.  Probe Comp is applied during reporting or by an external CAD program if the data is exported.
If you are measuring a cloud on a planar surface, please refer to the instructions found in Plane Measurement.  Other than the 'container' (Cloud vs Plane) the instructions are identical.
Creating a Touch Inspection
Selecting 3-Axis Touches or Head Touches
Depending on the hardware, you may have the option to choose between traditional 3-Axis Touches or Head Touches.  The type of touches to use should be selected before creating the inspection.  Instructions on how to choose the appropriate touch type can be found in Choosing 3-Axis or Head Touches.
Points in a Grid Pattern
Probing Support: PH10 (TP / SP25), PH20, REVO (RSP2 / RSP3)
  1. Select a surface from CAD to be measured.
  2. Touch type is determined by the settings in the Path Planning frame.  See Choosing 3-Axis or Head Touches.
  3. Points will be added automatically based on the user settings for the controls for Range, Target Point # and Margin.  The default method is to attempt to create points at the intervals requested by Target Point # based on the settings for Range and Margin.  Points will not be added where no surface exists (a hole).
Be sure to click Create Path to apply your settings.
Points Along the Edge
  3. Points will be added automatically along the edge of the surface by selecting Along Edge and adjusting the edge offset using Margin.  The number of loops and the point spacing may also be specified.
Manually Picked Points
  3. Points which were created automatically may be adjusted, or points may be added manually by using the tools available on the Points Tab.  Points may be entered manually by using the Keyin Point button or selected directly from CAD by using the Add Pick tool.
  4. It is possible to create a path using only points selected by the programmer.
    1. Use Select All to select all the points in the dialog.
    2. Use Delete Selected to remove all of the points.
    3. Use either Pick Points or Keyin Points to enter the desired points for the inspection.
