Due to the nature of the hardware during scanning it is sometimes necessary to control the head motion differently than the tip scanning motion. Instructions for controlling the head motion during a scan can be found in Controlling Head Motion during 5-Axis Scanning.3D Scan
Probing Support: PH10 (SP25), REVO (RSP2 & RSP3)
Please note that RSP2 for REVO is not designed for scanning perpendicular to a surface. Therefore, the user may need to select an appropriate tip prior to the measurement or utilize RSP3.
Default: Parallel LinesThe default 3D Scan Method creates a series of scan lines back and forth at even intervals across the surface. The ends of each scan line are connected to the end of the next in a rectangular back-and-forth scan pattern.
- Select a surface from CAD to be measured.
- Select the 3D option in the Scan Method frame.
- Select the # of Scan Lines to be added from the Scan Flow frame as well as the Margin to be used as an offset from the edges of the surface.
- You may change the direction of the main scan lines by selecting or de-selecting the Along Side 1 checkbox.
- Click Create Path to update your scan path.
Path planning does not check for voids in the surface for 3D scan paths. It is possible to edit the end points for each scan line on the Points Tab to shift the line to clear obstacles.Manually Picked Points
- Points may be added manually by using the tools available on the Points Tab. Points may be entered manually by using the Keyin Point button or selected directly from CAD by using the Add Pick tool.
- It is possible to create a path using only points selected by the programmer.
- Use Select All to select all the points in the dialog.
- Use Delete Selected to remove all of the points.
- Use either Pick Points or Keyin Points to enter the desired points for the inspection.
Be sure to click Create Path to apply your settings.Sweep Scan
Probing Support: REVO (RSP2)
Sweep scans are a method of collecting large amounts of data by rapidly sweeping the tip back and forth while moving the probe along a defined path.Simple Sweep ScanThe simplest sweep scan is a scan between a start and an end point. The probe head will move along the path between the start and end point while the tip sweeps back and forth rapidly at the same time. The area from which data is collected is typically a simple rectangular area.The first example shown here scans along the length of the surface and the sweep motion is a series of flat (or nearly so) lines. For proper motion control, several sections are required.
- Select the Sweep option in the Scan Method frame.
- A default path (start and end point) will be created.
- The probe head will move along Side 1 and the tip will sweep back and forth along the direction indicated by Side 2. The direction of the scan can be changed by unchecking Along Side 1.
- The default # of Sections is 2. Each section defines a start point, end point, or way point. The minimum number of sections is 2.
- The width of the sweep may be adjusted by changing Width.
- In order to control the amount of data collected and the number of "sweeps" between the start and end point, check the Overwrite Scan Param. checkbox. Then select the Scan Tab.
- Pitch determines the spacing between collected points in current units.
- Line Pitch determines the distance between each sweep crossing of the head path in current units.
At times, it may be necessary to break a surface into sections in order to successfully scan. This could be due to size constraints, or limitations based on the REVO scanning ability. In the following example, the sweep direction has been rotated. The REVO cannot sweep this surface due to the amount of undulation as it sweeps. Due to this, this surface would be broken into three sections as shown here. Two convex sections and a concave section.
- Along Side 1 has been unchecked to rotate the scan direction 90 degrees.
- Use Adjust Range as required to restrict that Scan area to a single direction curve.
- The width of the sweep may be adjusted by changing Width. The width should be adjusted to keep the scan on the simple curve surface.
- Height is adjusted to represent the height of the chord section as shown in the picture below. It is important that this be set correctly.
The first picture shows the results of a single scan path. Two more scans were added to fill in the surface. For the concave surface, a negative height was used.
