Controlling Head Motion during 5-Axis Scanning
Gasket Scan - Auto:
When Auto is selected for head motion, the machine XYZ axes and Head AB angles are all used to ensure that the stylus remains aligned with the local axis of the path.  This is the least efficient of the motion control options and may result in head motion that is much greater than the tip motion.
            Incident Angle controls the angle between the probe and the surface being scanned.
           Advance Angle offsets the probe with respect to the direction of travel.
            Videos below illustrate the effect of Advance Angle on the same scan path.
            Advance Angle = 0°
            Advance Angle = +20°
            Advance Angle = -20°
Gasket Scan - Fixed:
When Fixed is selected for head motion, a user specified head angle is used for all motion.  Only the CMM XYZ axes are used to control the scan.  This is much more efficient than the Auto head motion and the head position is much more predictable.
        Here is a plane being scanned with the fixed probe angle option with A = 60 & B = 0.
Gasket Scan - Head Rail:
The most efficient method of controlling head motion is the Head Rail option.  When Head Rail is selected, the CMM XYZ axes will be used to move the head/Z ram back and forth in a straight line while the head is rotated side to side to follow the path.
       Identical to Auto mode, Incident Angle controls the angle between the probe and the surface being scanned.
    Pick Path button under Scan Flow is used to specify the desired probe head path.
    Select 2 points on the feature will create a line that defines the probe motion during the scan. It was drawn in the
    same direction as "Side 2" in the example below.
    When the measurement is executed, the probe head rail will stay on the configured straight path while
    A and B axes are adjusted to maintain the specified incident angle and scan path.
   Sweep Scan:
    The head motion during Sweep Scan is comparable to Gasket Scan - Auto, meaning Incident and Advance
    Angles will dictate the path planning.
    The main difference is that REVO will oscillate A + B axes to cover a large area and collect large amount of data
    quickly. Additional details on how to configure the sweep scan can be found in this KB Article.
    Below is a video of Sweep Scan with Incident and Advance Angles of 30° and 0°, respectively.
