Scan on a Curve
Probing Support: PH10 (SP25), REVO (RSP2 / RSP3)
- Pick an edge or create a slice and pick the created slice.
- If you pick an edge, CMM-Manager will attempt to determine the feature type. For a curve, it will fail to fit a feature and you will be prompted to select [Cancel} to use the selection as a free-form (curve) feature.
- To create a slice, use the Measure Cross Section tool, create a cross-section, and add the polyline slice to the CAD for selection. Then select 2D and select the curve that was just created.
- Points will be added automatically based on the user settings for the controls for Range, Scan Pitch and Depth. Depth should be used when picking an edge. If a slice is selected, Depth will normally be zero.
- Point Interval is the number of control points for the scan. The sharper the curve, the more control points required. To control the amount of data collected, see Scan Pitch.
Be sure to click Create Path to apply your settings.
