The CMM-Manager Feature Inspection dialog includes several tabs which allow defining various aspects of the feature inspection. This article describes the options which are available on the Measurement Tab. The Measurement Tab is used to define the options which are used for auto path creation. The available options will vary depending on the specific type of feature being inspected.
Advanced Options
Applies to:
- Touch - Circle, Ellipse, Arc, Cylinder, Cone, Sphere, Hole Pattern
- Scan - All
Selecting the Advanced Options button will display the Advanced Options dialog.
- The Advanced Options dialog allows selection of the required fitting algorithm as well as various filtering options.
- The user can select from several different Fitting Algorithms. The contents of the drop-down list may vary depending on the type of feature being inspected.
- Filtering is available to filter out random noise as well as harmonic noise.
Apex
Applies to:
- Touch - Sphere
The Apex box contains a Pick button that allows the user to Click and Drag the position of the apex ('north pole') of a sphere. This may be an ID or OD sphere.
- Click the Pick button.
- A magenta square will be drawn at the current apex with a magenta line running to the center of the sphere.
- Using the finger cursor, click and drag the apex to the new position. The radial line follows the finger cursor.
- Release the mouse button. CMM-Manager will recalculate the inspection path using the new apex.
It may be easier in some cases to rotate the view so that the view is in line with the new desired apex. When the magenta line is covered by the square and the square is in line with the center of the sphere, you will be at the new 'north pole'.
Compensation
Applies to:
- Touch - All
- Scan - All
The Compensation box allows the user to determine if the feature should be auto compensated when inspected.
- Compensation On is the default for almost all features. Probe Compensation is calculated along the 3D vector from the center of the tip to the actual point of contact.
- Compensation Off is the default for 2D and 3D clouds. Clouds should almost always be inspected with compensation Off. Compensation would then be applied during reporting (Cloud 2 CAD) or by exporting the raw data to an external CAD package.
Note: Other than individual points, all features are compensated after data collection is complete along the vector of the calculated feature normal. This eliminates any cosine error that may results from touch data from points that did not contact the surface exactly normal to the surface being inspected.
Margin
Applies to:
- Touch - Plane, Circular Plane, Cloud
- Scan - Plane, Cloud
The Margin box allows the user to set the offset from the feature boundary for auto path planning for plane and surface features.
- To change the margin, enter a new value and click the Change button.
Measurable Points
Applies to:
- Touch - All except Hole Pattern
The Measurable Points box indicates the total number of points that path planning has determined can be accessed based on current settings or detected collisions. If the Measurable Points are less than the minimum required for the current feature, a warning message will be displayed.
The number of measurable points may be affected by:
- Available Tips - for path planning which does not use 5-axis path planning options (PH20/REVO), only pre-defined tips can be used in path planning.
- Feature Type.
- Settings on the DCC tab of the Machine Property dialog.
- Collision-free path calculations.
Mode
Applies to:
The Mode box allows the user to determine if the feature should be inspected manually or in program (automatic) mode.
- Manual mode - Part programs using Manual mode must be run in joystick mode using the joystick to take all measurements.
- Program mode - Part programs using Program mode will use DCC motion to move the machine and inspect features.
- Mode selection is only available for features which are taught using the joystick.
- To create a manually inspected feature without the joystick, use the Define Manual selection on the Features tab.
- To create Program Mode (Auto/DCC) feature without the joystick, use the Define DCC or CAD Teach options on the Features tab.
- Once the Feature Inspection dialog has been closed, this option cannot be changed.
Path Operations
Applies to:
- Touch
- Scan
The Path Operations box has buttons to allow the user to simulate or verify the current feature before accepting the path planning.
- Simulate - The virtual probe model color (if displayed) changes to yellow in the graphic display. The virtual probe follows the current probe path, including all moves, tip changes, and vector touches of the feature. The measurement path is executed on-screen only. The CMM does not move.
- Verify - The probe model color (if displayed) remains gray, and the measurement path is actually executed on the CMM. Any collected point or feature information is added to the Teach Mode database.
Range
Applies to:
- Touch - Line, Circle, Ellipse, Arc, Plane, Circular Plane, Cylinder, Cone, Sphere, Cloud
- Scan - Line, Circle, Ellipse, Arc, Plane, Cylinder, Cone, Sphere, Cloud
The Range box contains an Adjust button allows the user to change/define the boundaries of the area to be inspected on a feature.
- The range selections displayed will depend on the type of feature being inspected.
- In most cases, the user is allowed to pick and drag the boundaries, or enter values.
Plane Boundaries
Circle/Cylinder/Cone Sweep Range
Cylinder/Cone Height Range
Note: All features which allow range adjustment work in a similar manner.
Relative Measurement
Applies to:
- Touch - Point, Circle, Ellipse, Arc, Open Slot, Round Slot, Square Slot
Although Relative Measurement can be used for virtually any feature that includes support, it is typically used for sheet metal and plastic parts where the surface tends to be 'wavy' and targeting the correct depth to inspect a hole type feature can be difficult.
A common method of inspection of hole type features in sheet metal and plastic parts is to use a cylindrical probe and intentionally go a bit deeper than required to obtain the points. This method has its own set of problems. Using Relative Measurement, a standard spherical tip can be used to inspect the feature.
To inspect a feature using relative measure, the first step typically is to set the measurement Depth to 1/2 the material nominal thickness.
- With the Relative Measurement checkbox checked, CMM-Manager will place points offset from the edge of the feature using the Rad. Offset value. These points will be measured before the feature and used to create a small local plane to determine the actual height of the feature. Then Depth will be applied to that and the points for the feature acquired.
- It may be that the feature is also mis-positioned along the surface and the automatically created points may miss the surface and fall into the feature. One method of correcting this is to increase the Rad. Offset value.
- Using the Find Hole checkbox, a series of points will be taken inside the feature starting from the nominal center location. Like the temporary plane created by Relative Measurement, a temporary feature location is created and used for placement of the relative measure points. A Depth data entry box is activated. This allows the user to specify a depth for probing that is sure to touch the edges of the surface of the feature for the worst-case scenario of 'warp'. It is ok if these points are acquired with the probe shank as the actual feature measurement is done after the location and depth is determined.
- Using the actual feature location, relative measure points are placed, the plane is measured and used for depth determination, and the feature is then inspected.
Note: A pre-measured 4th plane may also be specified for Relative Measurement instead of taking points at feature inspection time.
Target Point #
Applies to:
- Touch - Line, Circle, Ellipse, Arc, Plane, Circular Plane, Cylinder, Cone, Cloud, Open Slot, Round Slot, Square Slot
The Target Point # window allows the user to specify the number of touch points needed to inspect the current feature.
- The contents of the Target Point # window varies depending on the type of feature being inspected. 2D features will simply show a total number of requested points. 3D features may request the total number of points along the length and width for a plane, or the number of sections and the number of points per section for features such as cylinders and cones.
- It may be that not all of the requested points can be measured based on current settings or detected potential collisions. Points that cannot be measured will be highlighted as magenta, and the Measurable Points window will show the number of points that CMM-Manager path planning can access. If there are insufficient points to inspect the feature, a warning dialog will be displayed.
Type
Applies to:
- Touch - Circle, Ellipse, Arc, Cylinder, Cone, Sphere, Hole Pattern, Open Slot, Round Slot, Square Slot
- Scan - Circle, Ellipse, Arc, Cylinder, Cone, Sphere, Round Slot, Square Slot
The Type box contains two option buttons to set the direction of the boundary vectors for the selected geometric feature.
- Inner means that all vectors point inward toward each other creating an internal feature (hole, slot).
- Outer means that all vectors point outward away from the feature surface creating an external feature (boss, web, rib).
