Using a cylinder as a primary axis
A cylinder has a centerline that may be used as an axis in an alignment.  When used as a primary axis/for leveling, unlike a plane, there is no zero point along that axis, so another feature must be used to define the origin along that axis.  In the example here, a point on the end was used to define the last axis origin.
In this example, there is no feature to use for the secondary axis (Align).  Since this is an incomplete (non-determinant) alignment, a Sync CAD will be required if this is the first full alignment, or a Runtime Align Part will be required if is another alignment following the first full alignment.
