Small Icons and Texts on High DPI Display with Scaling
Problem:
On a high resolution/DPI display such as a 4K monitor, the system display scale is often set above 100%, e.g. 125%-200%. The icons and texts in CMM-Manager, however, are still too small and not scaled properly according to the system setting.
Solution:
CMM-Manager is currently not DPI scaling aware, but there is a simple workaround.
  1. Right-click on the CMM-Manager desktop icon and  select Properties from the popup menu.
  2. Switch to the Compatibility tab and click the Change High DPI Settings button.
  3. Make changes to High DPI scaling override option as shown below:
  4. Click OK to confirm the changes.
If the above steps did not resolve the issue, please follow the instructions in the link below to load the default layout.
