Recommended PC Specs for CMM-Manager
Recommended PC Specs / System Requirements
Recommended PC Configuration
* - CMM-Manager may run on Windows 7 and 8.1 however, these versions of Windows are outdated and no longer supported by Microsoft.  QxSoft does not do any testing of CMM-Manager on Windows versions prior to Windows 10 and can only offer limited basic support for Windows versions prior to Windows 10.
Alert
CMM-Manager will not run on Windows XP.
Warning
CMM-Manager with Renishaw I++ on UCC Controllers does not support UCC Server version 5.6.x, 5.7.0, 5.7.1, or any 5.9.x release due to a regression in communication in UCC Server.
This affects any system running a UCC Controller with SP25, PH20, or REVO.  It may affect CMM-Manager Direct Connect 2.0 as well and usage of these versions is not recommended for Direct Connect 2.0 either.
** - Dual monitors are recommended for vision applications.
Alert
Note:  Certain HP desktops are known to have unreliable communications via the Mitutoyo ComUC style controllers.  We suggest using a Dell workstation in these cases.  https://www.dell.com/en-us/shop/desktop-computers/optiplex-tower-plus/spd/optiplex-7020t-plus-desktop
Accessibility
CMM-Manager, like virtually all Windows based programs, requires access to certain registry and file locations in order to function.  This requirement is based on the Microsoft application deployment specification.
By default, the CMM-Manager installer (attempts to) set the following permissions:
  1. c:\ProgramData\QxSoft [and all subdirectories and files] - "Everyone" - Full Control
  2. Registry HKCU\Software\QxSoft [and all subkeys] - "Everyone" - Full Control
  3. Registry HKLM\Software\QxSoft [and all subkeys] - "Everyone" - Full Control
IT restrictions or attempts to control these permissions at a more granular level cannot be supported by us as these requirements may go beyond simple users and may include access requriements for various windows processes and ID's.  Over-restrictive local policies may cause CMM-Manager to not function properly and may even result in loss of information.
System Specific Requirements
PC Slots and Ports
Please review these System Specific Requirements before obtaining a computer.  The computer hardware must be appropriate to support any required internal cards, communication ports, or have sufficient USB ports to support any required USB to Device adapters.
RS232/Serial
Many older controllers used a serial port to communicate with the controller.  In some cases, the probe head (PHC9/10) was also controlled by the PC via an RS232/Serial port.  The PC will need sufficient serial ports to handle the required number of connections.  This is typically 1 or 2, but in the case of older Pantec/Wenzel controllers, it could be as many as 3.
Info
If a USB to Serial adapter is used, we strongly recommend using the IO Gear USB to Serial adapter -  - http://www.iogear.com/products/GUC232A/
GPIB
A few controllers utilize GPIB communication for the controller, probe head controller, or both.  An appropriate National Instruments GPIB card or USB to GPIB adapter will need to be available.
Info
Please see National Instruments GPIB Adapters for further information.
Ethernet
Many new controllers communicate via an ethernet cable.  In these cases, when a connection to the internet or local network is also desired, a 2nd ethernet adapter must be used.  This can either be an internal card, or a USB to Ethernet adapter.
Other
A few controllers use a proprietary communication card.  The host computer must have available slot(s) to support these cards.
