CMM-Manager has several standard data filters for scan data to filter out random noise as well as harmonic noise.
- Selecting the Elimination Filter option will allow the user to apply a Standard Deviation filter to remove random noise from scanned data. The user may define the number of Standard Deviations to use for filtering. A smaller number removes more noise but may also remove valid data. A larger number will remove less noise and may leave some invalid data. Specifying a Standard Deviation of 3 would eliminate any data points that are more than 3 Standard Deviations from the mean.
- Selecting a Filter Type allows filtering repeating harmonic errors from scanned data. The Linear and Circular filters smooth repeating harmonic errors.
- Off: Turns harmonic filtering off
- Linear: filters harmonic errors along a linear distance based on the user specification for wavelength in mm.
- For 3D features, the filtering is performed along the path of the scan data.
- Wavelength - determines the number of undulations along a surface length. The available wavelengths are shown in the drop-down list, in millimeters. Frequencies higher than the selected wavelength (i.e. with a smaller wavelength) are filtered out. For example, if you select 25 mm, there can only be one undulation every 25 mm, so the data is approximated to a wavelength of 25 mm and smaller wavelengths have an exponentially smaller effect on the approximation. In the example above, Control Correction would remain, but Tool Harmonics and Surface Finish would be filtered out.
- Example: A value of 25 mm establishes the location of the feature and filters out noise or small surface undulations (Tool Harmonics and Surface Finish above). A value of 2.5 mm filters out the high frequency oscillations (Surface Finish above) and gives the overall shape of the feature. A value of 0.25 mm gives the actual surface finish.
- Available values are 0.08, 0.25, 0.8, 2.5, 8.0, 25, 80, and 250.
- This filter also supports cylinder features
- The cylinder scan method must be "Lines" or use points clouds where points should be non-intersecting, parallel lines aligned with the cylinder axis.
- The scan pitch must be at least 3x the lateral distance between adjacent lines to ensure proper filtering application.
- Points are automatically clustered into individual lines based on the lateral distance between them
- Each cluster, a line, is filtered independently using the specified wavelength
- Wavelength selection follows the same guidelines as above
- Circular: filters harmonic errors around a circular feature based on the user specification for UPR (undulations per revolution).
- The basic concept is the same as the linear filter. However, instead of allowable undulations along a length, circular features allow a specified number of undulations per revolution. (UPR)
- The minimum number of points is 10 times the number of undulations required in the circumference. A UPR filter of 15 would require a minimum of 150 points.
- UPR - the number of peaks allowed around the circumference. For example, if you select 5, then there can only be five peaks, so the data is approximated to five peaks. The approximation calculates the five most significant peaks and filters out the rest.
- A value of 5 undulations per revolution (UPR) establishes the location of the feature, and gives a good circularity value, but at the expense of information. A value of 15 UPR gives the overall shape of the feature. A value of 50+ UPR gives the actual surface finish.
- Feature size is a factor, so you must adjust the filter accordingly. A large circle will require a higher UPR value to reduce noise and achieve a good approximation to the surface.
- Available values are 5, 15, 50, 150, and 500.
- This filter also supports cylinder features.
- The cylinder scan method must be "Circles" or use point clouds where points line on concentric circular paths centered on the cylinder axis and at discrete axial heights
- Points are automatically clustered into circles based on their axial height.
- Each cluster, a circle, is filtered independently using the specified UPR.
- UPR selection follows the same guidelines as above.
- Helical: filters harmonic errors along a helical path of a feature scan based on the user specified UPR (undulations per revolution).
- This concept is similar to the linear filtering as the filtering is performed along the length of the scan but amount of filtering is based on the set UPR and number of revolutions performed.
- Each revolution of the helical scan must have at least 10 evenly spaced points in order for the filter to work properly.
- The minimum number of points per revolution is 10 times the specified UPR. A UPR of 15 would require at least 150 points for every revolution of the helical scan.
- UPR - the number of peaks allowed per revolution. For example if UPR is set to 5, there can be 5 times the number of revolution peaks. The approximation calculates this number, UPR times the number of revolutions, of peaks and filters out the rest.
- Feature size is a factor, so you must adjust the filter accordingly. A large cylinder will require a higher UPR value to reduce noise and achieve a good approximation to the surface.
