Note: The following steps only apply to CMM-Manager versions 3.10 and above
There is a known installation error that can occur on Windows 7 systems with the installation of the VC Runtime Redistributable.
The install will make it about ¾ of the way through before failing and rolling back the install.
This error will be noted in the collected installation logs as a failure to install the VS2017_Redist_x64_exe component.
The commonly seen issue is the redistributable will try to install needed Windows 7 Updates, e.g., Windows6.1-KB2999226-x64.msu, but fails.
It is important to confirm which service pack of Windows 7 the target machine has installed, since the updates in the VC redistributable tries to install requires Windows 7 Service Pack 1.
To confirm:
- Right-click My Computer, found on the Windows desktop or in the Start menu.
- Select Properties in the popup menu.
- In the System Properties window, under the General tab, the version of Windows is displayed, and the currently-installed Windows Service Pack.
- If not at Windows 7 SP1, run the needed Windows updates to upgrade to Windows 7 SP1.
If the target system is already Windows 7 Service Pack 1:
- Make sure there are no pending Windows updates needing applied. If there are, run Windows Update installing all needed updates.
- Restart the target system.
- Try installing CMM-Manager again.
- If there are still issues installing, please collect and send any CMM-Manager installation logs. Refer to: How to Collect CMM-Manager Installation Logs
