This Knowledge Base article describes how to configure and report Profile using the CMM-Manager interface. For a detailed description the Profile tolerance and how it is properly applied, refer to the appropriate topic in the current ASME 14.5 Dimensioning and Tolerancing publication, which is available from ASME at https://www.asme.org.
To report Profile, select Profile from Report | GD&T on the Ribbon Bar. CMM-Manager will automatically switch between surface and line profile depending on the controlled feature type.
Enter the required information and parameters then select Preview or click OK to complete the operation.
Title (Optional):
Enter text here to display items such as Balloon numbers or Key Characteristic numbers from the print in the report.
Profile Type:
- Surface Profile - Select this option if your print is requesting the profile of a surface.
- Line Profile - Select this option if your print is requesting the profile of a line.
- Form Only - CMM-Manager will measure the profile to the feature itself (no datum lock).
- This option is intended for open form features such as surfaces and curves, NOT closed form features such as circles, cylinder, spheres, etc. For geometric features, please use the appropriate form item in Feature Report (See: GD&T - Circularity, Cylindricity, Straightness, & Flatness)
Viewing Plane:
- XY, YZ, ZX, and 4th Plane - Select the viewing plane to be used to determine the direction of the profile evaluation.
- Group Band Width - Specify the band width to be used for grouping the measurement points for evaluation.
Tolerance Zone:
For the bilateral tolerance zone, please ensure that the Use Total Zone option is checked.
The unilateral tolerance zone will be enforced if the Use Total Zone is unchecked. The sum of upper and lower tolerances must equal to the total tolerance zone value.
Reporting Feature:
- Enter the controlled feature(s) to be reported. Valid combinations are...
- Surface features (planes, cones, cylinders, etc.)
- Curve features (line and circles)
- Clouds (for measuring the profile of complex surfaces
- If multiple features are selected, the output will reflect the highest deviation.
- The user can either click on the Display Windows or drag-and-drop from the Feature Database to specify controlled features(s).
CAD Surface List:
When cloud(s) are selected under Reporting Features, corresponding CAD surfaces must be defined to calculate the profile. CMM-Manager will select the CAD surface related to the specified cloud(s) automatically; however, it can be added/deleted/modified if necessary.
Datum Features:
- Current Ref. Frame - When this option is selected, CMM-Manager will utilize the current part reference frame for the profile calculation.
- Therefore, please ensure that the current reference frame represents the datum scheme required for the profile measurement prior to the reporting.
- New Ref. Frame - CMM-Manager will construct the datum reference frame on-the-spot for the calculation based on features selected for Features #1, #2, and #3. The orientation of the new reference frame can be seen in the Display Window.
- Feature #1, #2, and #3 - Specify datum features (primary, secondary, and tertiary) for the profile measurement.
- If Current Ref. Frame is enabled, the listing datum features here is for the visual purpose only (will not affect the measurement) and optional.
- If New Ref. Frame is enabled, specifying datum features here is mandatory to construct the temporary reference frame.
Not all datum structures are supported for constructing within the profile report. If an error is encountered, please enable Current Ref. Frame option and create the reference frame beforehand.
Datum Lock:
If any of the checkboxes is unchecked, CMM-Manager will perform the best fit in the specified translational and/or rotational axes. This function can be used to simulate the profile measurement with partially constrained datum reference frame where not all degrees of freedom are restricted. The user is allowed to check/uncheck options to override the default configuration if necessary.
When the New Ref. Frame option is selected under Datum Features then specify features, CMM-Manager will automatically lock/unlock rotational and translational axes accordingly. The manual override is possible.
Notes:
- Enter optional descriptive text to be displayed as a note in the report output.
Example:
Here is an example on how to report the profile of a complex surface with respect to Datum AB shown in the picture below.
