GD&T - Form: Circularity, Cylindricity, Straightness, & Flatness
This Knowledge Base article describes how to configure and report Circularity, Cylindricity, Straightness, and Flatness using the CMM-Manager interface. For detailed descriptions of these tolerances and how they are properly applied, refer to the appropriate topic in the current ASME 14.5 Dimensioning and Tolerancing publication, which is available from ASME at https://www.asme.org.
A form report shows the form error of a feature based on the calculated (actual) feature, free from any datum constraints.
Alert
Please note that form errors, even though defined by ASME/ISO, are not zone tolerances like position, profile, angularity, etc.  They are a value only tolerance.  This means that the result is not doubled to arrive at the reported value.
If you attempt to use Form Graphical Report to see the min/max values, by default, it shows a diameter value.  This is not the value used for simple form.  To see the min/max used to calculate form, please enable Graphical Report | Deviation | Mark Max/Min to see the simple Min/Max values.
Examples:
The form (straightness) of the line below is calculated by creating a minimum parallel zone which contains all of the points.  This zone is parallel to the calculated feature.  The form (circularity) of the circle below is calculated by creating a minimum concentric zone which contains all of the points.  This zone is concentric with the calculated feature.
In order to pass, the calculated zones must not exceed the specified form tolerance.
These same concepts apply to Flatness and Cylindricity but projected into 3D.
Reporting:
To report any of these form-related GD&T tolerances, please select Feature from Report => Basic Reporting on the Ribbon Bar.
Enter the required information and parameters then select Preview or click OK to complete the operation.
Title (Optional - CMM-Manager 2022 or above):
  1. Enter text here to display items such as Balloon numbers or Key Characteristic numbers from the print in the report.
Feature:
  1. Enter the controlled feature to be reported.  All CMM-Manager pick options are available.
Type (Read Only) :
  1. Type displays the actual feature type since it is not required that the Feature Name contains the feature type as part of the name.
Index:
  1. Selecting Index allows accessing multiple features of the same name which were created in a VB Script loop.  If this option is selected, a numeric input box will be displayed to enter the desired index number of the feature.
Note:
  1. Enter optional descriptive text to be displayed as a note in the report output.
Tolerance Type:
  1. The last item on the tolerance type is the form error, so please ensure that the box is checked to output the result.
  2. Enter the specified tolerance value obtained from the print under Upper Tol.
  1. CMM-Manager will automatically choose the appropriate GD&T type depending on the controlled feature selection.
