This Knowledge Base article describes how to configure and report Bilateral Position using CMM-Manager. For a detailed description of the Bilateral Position tolerance and how it is properly applied, refer to the appropriate topic in the current ASME 14.5 Dimensioning and Tolerancing publication, which is available from ASME website: https://www.asme.org/
Unlike the regular True Position, Bilateral Position uses the parallel tolerance zone, thus the orientation of a feature will affect the positioning tolerances. This method is typically applied for a slot. The link below provides a simple overview of Bilateral True Position.
To report a Bilateral Position of a feature, click the Bilateral Position icon from Report => GD&T in the Ribbon Bar.
Enter the required information and parameters then select Preview or click OK to complete the operation.
Title (Optional - CMM-Manager 2022 or above):
Enter text here to display items such as Balloon numbers or Key Characteristic numbers from the print in the report.
Feature:
- Enter the controlled feature to be reported. All CMM-Manager pick options are available.
Type (Read Only) :
- Type displays the actual feature type since it is not required that the Feature Name contains the feature type as part of the name.
Index:
- Selecting Index allows accessing multiple features of the same name which were created in a VB Script loop. If this option is selected, a numeric input box will be displayed to enter the desired index number of the feature.
Note:
- Enter optional descriptive text to be displayed as a note in the report output.
Tolerance Zone:
- Tolerance - The specified tolerance value obtained from the print.
- Material Condition:
- RFS is selected by default.
- MMC and LMC are enabled only if:
- The controlled feature is a feature of size.
- The size of the controlled feature has been reported prior to this output.
- Datum - The reference feature or a datum plane/axis. All CMM-Manager pick options are available.
Use Current Ref. Frame:
- When this option is selected, the bilateral position of a feature is measured from the current reference frame. Please ensure that the reference frame represents the datum structure specified in the print before reporting.
- Datum Feature #1, #2, and #3 are used to indicate primary, secondary, and tertiary datums on the report. The material conditions can be assigned to datums here; however, size of the datum feature must be reported prior to this operation. If no material modifier is involved, specifying datums is optional
Unlike the True Position, Create New Reference Frame option is not available for Bilateral Position.
Nominal Position:
- The nominal position of the feature can be updated here.
- The radio button selection within the Nominal Position determines the direction of the parallel tolerance zone. For example, the selection shown in the picture below will draw the tolerance zone perpendicular to the Y-axis. Switch to the Polar coordinate system if the tolerance zone must be constructed in the radial direction.
Please ensure that one of the axes is perpendicular to the tolerance zone direction so it can be selected. Specifying an incorrect zone may result in inaccurate tolerance calculations.
Feature Rpt:
- This is the option to combine the feature report information with the true position report. Once the box is checked, Feature Report tab will appear, and the user can report location, size, and form of the feature. This is a convenient way to output the size of the feature for MMC/LMC.
Tolerances for the feature location (X, Y, Z, R, & A) is not included in the report by default, thus they do not affect pass/fail status of the part unless "Show Location Tolerance" options is enabled.
Show Location Tolerances:
- When this option is enabled along with Feature Report, the feature location in cartesian and polar coordinate systems will affect pass/fail status.
