Bilateral True Position of a Slot
Bilateral True Position (Slot actual parallel to slot nominal)
This is how most people think of True Position.  It is simply derived from the “offset” of the actual to the nominal.
In our example here, we have a tolerance band of +/- 0.025 (TP tolerance of 0.050).  The slot is shifted 0.010 to the right.  The difference between the nominal and actual is 0.010 mm.  This is doubled for TP output, so our TP actual would be 0.020.  Well within limits.
Bilateral True Position (Slot actual not parallel to slot nominal)
Bilateral True Position also considers the tilt (and form) of the feature.
This is the same slot.  It still has the same basic 0.010 “offset” in the center, but it is also twisted somewhat (exaggerated here for clarity).  The True Position is still calculated based on the original nominal which is still parallel to the axis system!  The largest distance from nominal is used for the calculation.  In our example here, the top end of the actual slot is at about 0.030 from nominal.  Doubled, that would be 0.060 which would exceed the TP tolerance of 0.050 by 0.010.
    • Related Articles
    • GD&T - Bilateral True Position
      This Knowledge Base article describes how to configure and report Bilateral Position using CMM-Manager. For a detailed description of the Bilateral Position tolerance and how it is properly applied, refer to the appropriate topic in the current ASME ...
    • Position Graphics for Report (OutTol Column)
      There are two different position graphics that can be displayed in the OutTol column. These graphics are for True and Bilateral Position reports which can be found in the GD&T section of the Report ribbon bar. To display these graphics they must be ...
    • GD&T - True Position
      This Knowledge Base article describes how to configure and report True Position using CMM-Manager. For a detailed description of the True Position tolerance and how it is properly applied, refer to the appropriate topic in the current ASME 14.5 ...
    • True Position of a Cylinder
      True Position (Cylinder perpendicular to the axis system) This is how most people think of True Position. It is simply derived from the “offset” of the actual to the nominal. In our example here, we have a tolerance band of +/- 0.025 (TP tolerance of ...
    • Replacement PC with PCI expansion slot
      Some CMM Interfaces Still Require Full-Size PCI Expansion Cards Several CMM interfaces, especially those tied to legacy controllers, probe systems, or motion control hardware, still rely on full-size PCI expansion cards including: Mitutoyo UC - ComUC ...
    CMM-Manager YouTube Channel
