2D Cloud Measurement - Touch
CMM-Manager supports 2D Cloud measurement by using touches or scanning.
Alert
Points collected for Cloud inspection are almost always collected with Probe Comp off.  Probe Comp is applied during reporting or by an external CAD program if the data is exported.
Creating a Touch Inspection
Selecting 3-Axis Touches or Head Touches
Depending on the hardware, you may choose to use traditional 3-Axis Touches or Head Touches.  The type of touches to use should be selected before creating the inspection.  Instructions on how to choose the appropriate touch type can be found in Choosing 3-Axis or Head Touches.
Points on a Curve
Probing Support: PH10 (TP / SP25), PH20, REVO (RSP2 / RSP3)
  1. Pick an edge or create a slice and pick the created slice.
    1. If you pick an edge, CMM-Manager will attempt to determine the feature type.  For a curve, it will fail to fit a feature and you will be prompted to select [Cancel} to use the selection as a free-form (curve) feature.
    2. To create a slice, use the Measure Cross Section tool, create a cross-section, and add the polyline slice to the CAD for selection.  Then select 2D and select the curve that was just created.
  2. Points will be added automatically based on the user settings for the controls for Range, Target Point # and Depth.  Depth should be used when picking an edge.  If a slice is selected, Depth will normally be zero.
Be sure to click Create Path to apply your settings.
Picking an Edge
Creating a Slice
2D Cloud Settings
Collected Data
