NOTE: By default, Windows marks "ProgramData" as a hidden directory. You may either type the path in the address bar, bypassing the hidden setting, or change the Windows files settings
to display Hidden Files and Folders
Version 2020 and later:
C:\ProgramData\QxSoft\CMM-Manager xxx_version\Logs
Version 3.10 and earlier:
C:\ProgramData\Nikon\CMM-Manager xxx_version\Logs
The files are saved in a format similar to CMMMgrCrashReport_3.10.1.7968_11112020_151521.dmp. It is possible that there may be several crash dumps in that location. Check the file date/time to determine the appropriate file to send. The date/time is also encoded in the file name. In the above example, the crash occurred on 11-11-2020 at 15:15:21 (3:15 PM).
