Warning about Incomplete Reference Frame before Program Execution
You are seeing this warning because your part program is attempting to execute an automated Direct Computer Control (DCC) measurement operation before establishing a fully determinant part reference frame.
Why the Warning Appears
- Incomplete Alignment Steps: For a part reference frame to be "determinant," all six degrees of freedom (three translational axes along X, Y, Z and three rotational axes around X, Y, Z) must be fully established and constrained. The warning pops up if the alignment sequence preceding your DCC measurement operation is missing a required step, such as "Set Origin", "Level", and "Align".
- Inspection Path Risk: Executing automated DCC movements without locking down all six degrees of freedom means the software cannot accurately calculate the part's spatial orientation, which can cause invalid inspection path calculations or potential probe collisions.
How to Fix or Manage the Warning
- Complete the Alignment: Ensure that your initial manual alignment sequence fully locks all six degrees of freedom (for example, using a standard 3-2-1 Alignment or establishing Level, Align, and Set Origin operations) before initiating DCC operations.
- Toggle the Warning Preference: If you deliberately intend to execute a DCC motion without an alignment (e.g., when no manual alignment is required due to proper fixturing), you can disable this determinant reference frame prompt in CMM-Manager under Preferences → General → Program Running → Show warning if reference frame is not complete before DCC measurement.
