The View Toolbar is a dedicated vertical toolbar docked along the left edge of the 3D Display Window. Its primary purpose is to provide immediate, one-click access to the most frequently used graphical view manipulation and display commands without requiring you to switch tabs on the Ribbon Bar.
Following functions are available in View Toolbar:
- Zoom Controls
- Zoom In: Zooms into the graphics view in 25% increments (equivalent to rolling the mouse wheel forward).
- Zoom Out: Zooms out of the graphics view in 25% increments (equivalent to rolling the mouse wheel backward).
- Zoom All: Immediately fits all CAD geometry, probe assemblies, and measured features into the visible graphics view.
- Zoom Slide: Dynamically scales the zoom level using smooth drag motions.
- Zoom to a Window (Zoom Box): Allows you to drag a rectangular box over a specific area of the part to magnify that detail.
- Pan and Rotate Navigation
- Translate (Pan): Activates view translation mode, allowing you to click and drag the part view across the window.
- Rotate (Orbit): Activates 3D orbit mode to rotate the part and probe dynamically in space.
- Set Center of Rotation: Allows you to pick a specific point or feature on the CAD model to serve as the exact focal pivot center for subsequent rotations.
- View Perspectives
- Set View Port (Predefined Views): Displays the eye icon menu to instantly snap the camera to any of the 10 standard predefined views (Top, Bottom, Front, Back, Left, Right, and 4 Isometric perspectives), recall custom user-saved view angles, or toggle CAD display visibility.
- CAD Display Modes
- Display CAD Surfaces in Wireframe: Switches the 3D CAD model rendering to a lightweight wireframe structure.
- Display CAD Surfaces in Shaded: Renders the CAD model with solid shaded surfaces and lighting.
- Display CAD Surfaces in Shaded with Edge: Renders the CAD model with solid shaded surfaces and lighting as well as all edges highlighted.
- Report & Deviation Inspection Tools (Report View Only)
- View Feature Label: Allows you to click any feature on the screen to display a light yellow callout box showing its feature label.
- Increase Deviation Magnification: Scales up the visual whiskers/vectors representing measurement deviations on CAD surfaces or contours.
- Decrease Deviation Magnification: Scales down the visual deviation magnification.
