It is very common to use a "cylinder" tip when inspecting thin parts such as sheet metal and molded plastic. Here are some tips on proper usage of cylinder tips.
CMM-Manager allows you to create (or simulate) two different types of cylinder probes. Flat / square end, and the (now) more common spherical end.
Note: The first probe assembly (Probe Assembly 0 by default) cannot be a cylinder probe
- If you select 'Cylinder' as the type in CMM-Manager, you will be prompted to enter the dimensions for a flat end cylinder tip. There is also a place to specify "offset" which is the distance from the end of the tip to be used for taking touches.
- If you wish to define a spherical end cylinder probe, define it and calibrate it as though it is a standard spherical tip. Do not select the type as 'Cylinder'. This type of cylinder probe is actually much more flexible for use in various applications. Since the size of the cylinder portion is the same as the size as the spherical tip, the diameter and offset of the cylinder portion is inferred from the calibration of the tip.
Calibrating flat end cylinder probes
- When calibrating a flat end cylinder probe in CMM-Manager, the calibration path will be like a standard spherical tip. The first touch on top of the sphere is used to determine how far down to go to take the calibration touches are around the equator of the sphere. Only the horizontal offsets and diameter are calibrated.
- A ring gauge may also be use for calibration of flat end cylinder probes. This will be slightly less accurate since the cylinder my not be exactly square to the surface of the ring gauge. The end of the tip could touch on one side and the shank could touch at the top of the ring gauge on the other side affecting both size and form. The calibration will be a circular path (no length offset correction). The offset position will be used for depth for probing.
Note: The ring gauge must be defined and located before use, just like a calibration sphere.
Calibrating a flat cylinder tip - Sphere
Calibrating a flat cylinder tip - Ring gauge
Calibrating spherical end cylinder probes
Spherical end cylinder probes are defined and calibrated as though they were simple spherical tips. Since the size of the cylinder portion is the same as the size as the spherical tip, the diameter and offset of the cylinder portion is inferred from the calibration of the tip.
Calibrating a spherical cylinder tipUsing a cylinder probe (both types)
