Troubleshooting - Text font changed to Helvetica in PDF report
When CMM-Manager report is saved to PDF format, text font might be changed from Arial to Helvetica. These two fonts are very similar but some characters are different. If this is not desirable, please follow the steps below to disable the conversion.
  1. Go to Windows Settings > Printers & Scanners
  2. Click on QX PDF Writer, and select Manage
  3. Select Printer Properties
  4. Select the Device Settings tab on the QX PDF Writer Properties dialog
  5. Find Arial Under Font Substitution Table, and change settings from Helvetica to <Don't Substitute>
  6. Click OK
