Troubleshooting - DRO font not loaded correctly
In some instances, it is possible that the correct font is not loaded during installation if:
- The font is being used by a different application
- The file was not overwritten at the time of installation
- The file is corrupted for whatever reason
In either of these cases, it is necessary to reboot the system after the installation is complete to release and load the correct font in order to avoid the B angle as shown below:
A similar issue can be found in other dialogs such as:
- Measurement counter dialogs
- Watch window
- DMIS measurement counter dialog
- SFL DRO
To resolve this issue, perform the following steps:
- Reboot the PC and verify if the DRO font is loaded as intended
- If the issue persists
- Shut down CMM-Manager
- Browse to the "C:\Windows\Fonts" folder
- Delete the IQDigitalReadOut Regular font
- Launch CMM-Manager and verify if the DRO is updated as expected
- Reinstall CMM-Manager
- Reboot the PC
- The issue should be resolved at this point.
Related Articles
Troubleshooting - Text font changed to Helvetica in PDF report
When CMM-Manager report is saved to PDF format, text font might be changed from Arial to Helvetica. These two fonts are very similar but some characters are different. If this is not desirable, please follow the steps below to disable the conversion. ...
Helmel - Pro Counter II / III(Manual)
ProCounter II - works with OS up to Windows XP(32 bit) ProCounter III - works with newer OS including Windows 7 (32 and 64 bit)
Losing CAD model in graphical report - Run Results File
Possible issue: Any time you save a run file from a program that uses CAD models for graphical reports, those same graphics remain in those run files. However, if a change is made to the run file and saved, the CAD model disappears from the graphical ...
CMM-Manager Licensing Troubleshooting
CMM-Manager will not launch You may see an error such as Feature Expired (41) or similar indicating the software will close or cannot be launched. Read below to learn how to troubleshoot an expired or faulty CMM-Manager license. Many times the ...
How to Restore CMM-Manager UI when Buttons & Icons are Missing
Please follow the troubleshooting guide below to recover buttons and icons missing from CMM-Manager's UI. Method 1: Recover by Loading the Default Layout Click on the Layout icon located at the top right corner of the window then select Load. ...
CMM-Manager YouTube Channel
