The Status Bar in CMM-Manager stretches across the very bottom of your screen, serving as both a live operational monitor and a handy control dashboard. Instead of making you dig through menus to check basic settings or issue common commands, it gives you an instant readout of your setup and lets you click right on its individual sections to make quick adjustments.
Prompt Pane
The Prompt pane is the leftmost section of the Status Bar, acting as the software's direct voice to the operator. Throughout your inspection workflow, it gives you a continuous stream of real-time feedback, operational cues, and step-by-step guidance so you always know what the system is doing and what action it expects next.
When the machine is idle and waiting on your next move, the pane simply displays general controller and system status messages, most often showing a clear "Ready". As soon as you kick off an active command—whether that is qualifying a probe stylus, running an alignment, or taking individual feature points—the text changes dynamically to guide you through the process, prompting you to move to clearance height, take the next touch point, or adjust probe positioning.
Abort CMM
The Abort CMM button is a circular red button featuring white curved arrows, located right next to the Prompt pane on motorized (DCC) and vision machines.
Its primary function is to cancel or abort the active CMM motion command. In practice, it serves as an on-screen "soft" emergency stop. If you notice an unexpected trajectory, potential clearance problem, or collision hazard during automated moves, you can click this button right from the interface to halt the machine's movement on the spot.
Because it operates as a software-level abort rather than tripping the physical hardware E-stop button on the controller or joystick, it allows you to stop active motion smoothly without cutting main drive power, making it much faster and cleaner to recover your position and resume your inspection workflow. You can also find this same command under the System tab in the Machine ribbon group if you prefer accessing it from the top menu.
Joystick / Auto Mode
The Motion Mode pane on the Status Bar—often called the Joystick / Auto Mode button—is an interactive indicator and toggle located directly beside the red Abort CMM button. An amber-highlighted joystick icon indicates the CMM is currently in Joystick Mode, while an unhighlighted icon indicates the machine is in Auto (DCC) Mode.
Clicking this pane instantly switches axis motion control between manual operator driving via the physical jogbox and automated machine travel under Direct Computer Control (DCC). It mirrors the function of the Joystick / DCC button found under the System tab on the Ribbon Bar.
Push this button to switch into Joystick Mode whenever you need to manually drive the probe to a safe clearance height, perform a manual part setup, measure features without CAD or prints, or locate calibration spheres and ring gauges.
Push it to switch into Auto Mode once the stylus is clear of obstacles and you are ready for CMM-Manager to automatically drive the axes to execute an inspection program, perform automated DCC re-measurement, or run probe tip qualifications. Also, CMM-Manager displays "DCC Mode Please" in the Display Window during the program execution if the next command requires the machine to be in the DCC mode.
C/S Sync Status
The C/S Sync Status icon is an indicator positioned between the Motion Mode and Probe Assembly panes. It displays a green check mark when the imported CAD model's coordinate reference frame matches the active part reference frame, and switches to a red X when the CAD model and part coordinate systems are out of synchronization.
A green check mark ensures that nominal dimensions, feature locations, and probe approach vectors generated from the 3D model correspond directly to the physical workpiece on the CMM table. Attempting to program or measure features using CAD Teach while the red X is displayed may cause incorrect vector approaches, inaccurate measurement results, or machine collisions.
CMM-Manager automatically synchronizes both frames once you complete a determinant part alignment through standard Level, Align, and Origin operations. If the CAD model is imported after creating an alignment or if the coordinate system is altered later, you can manually re-establish synchronization using the Sync CAD tool located under the Import/Export tab on the Ribbon Bar.
Probe Assembly
The Probe Assembly pane on the Status Bar is an interactive status indicator and shortcut located between the Motion Mode and Active Tip panes. It displays a probe icon alongside the name or index of the active probe assembly, confirming which hardware configuration CMM-Manager is currently using. In multi-sensor vision systems, this section becomes the Sensor Type pane, showing either a tactile probe or a camera lens icon.
Clicking this pane immediately opens the Probe Assembly setup dialog. It serves as a one-click shortcut to the same management window accessed from the Probe tab on the Ribbon Bar.
Use this pane to verify that the physical tool mounted on the probe head matches software expectations before running automated part programs. Click it whenever you need to build or modify probe assemblies, adjust extension bar lengths, define stylus dimensions, or assign probe configurations to ports on an automatic tool changer rack for automated stylus changing.
Active Tip
The Active Tip pane is an interactive status indicator and shortcut located between the Probe Assembly and Units panes. It displays the label of the active stylus tip, typically indicating the current A and B wrist angles of an indexing probe head, such as 2x20_A0B0.
Clicking this pane immediately opens the Tip Manager dialog window. It provides a direct one-click shortcut to the same management window found under the Probe tab on the Ribbon Bar.
Use this pane to verify probe orientation before measuring features on different part faces. Click it to choose another angle and click Select, which automatically inserts a Get Tip command when programming in Teach-On mode. It also provides fast access to check probe calibration status, inspect measured tip diameters and form errors, launch automated tip calibration routines against a reference sphere, or define new probe angle sets.
Units
The Unit pane on the Status Bar is an interactive readout and toggle located between the Active Tip and Current Reference Frame panes. It displays the active linear measurement system, indicating either MM for millimeters or INCH for inches.
Clicking this pane immediately toggles the active measurement unit between millimeters and inches across the entire CMM-Manager environment. The software instantly recalculates coordinates, feature dimensions, and digital readouts into the selected unit system without altering part nominals.
Use this control whenever you need to align your working inspection environment with blueprint requirements that differ from the current system setting. It provides a quick way to switch units on the fly without navigating through setup menus. Furthermore, the measurement units active when saving a part program determine the program's saved unit setting, synchronizing directly with the Unit tab in Program Settings.
The Current Reference Frame pane displays the name of the active coordinate system, showing MACHINE when operating in raw machine coordinates, the specific name of an active part alignment, or "Unnamed" if a newly created alignment has not yet been explicitly saved.
Clicking this pane immediately opens the Reference Frame List dialog window. It serves as a single-click shortcut to the coordinate system management tools located under the Alignment tab on the Ribbon Bar.
Use this pane before measuring or reporting features to confirm at a glance which alignment currently controls the digital readout (DRO), CAD display position, and reported inspection values. Click it whenever you need to inspect all saved coordinate systems in the project, recall an existing datum reference frame, delete obsolete frames, or import alignments created across different operation modes.
More
The MORE... pane is the rightmost interactive control on the CMM-Manager Status Bar, positioned directly after the Current Reference Frame pane.
Clicking this pane immediately opens the Machine Property dialog window. It functions as a direct single-click shortcut to the machine settings command located under the System tab on the Ribbon Bar.
Use this shortcut whenever you need fast access to inspect or configure system-level hardware parameters. It allows you to check machine motion boundaries, table travel limits, controller setup options, and reference sphere properties without leaving your current workspace or browsing through ribbon menus.
