CMM-Manager supports four scan types.
- 3-Axis: CMM XYZ motion only
- Fixed Quill: Head motion only (REVO)
- 5-Axis: CMM XYZ + Head motion (REVO)
- 5-Axis Sweep: Special - CMM XYZ + Head motion (REVO)
3-Axis
Probing Support: PH10 (SP25), REVO (*RSP2 / RSP3)
3-axis scanning uses only CMM XYZ axis motion to follow the scan path. This is the traditional method of scanning. With a 3-axis scan, the proper probe angle is selected, the tip is placed in contact with the surface to be scanned, and the CMM moves along programmed scan path to acquire the scan data.
This is much less efficient than a the remining scan types since the mass of the entire CMM frame must be moved to follow the scan path.
Note: The REVO, using RSP2 technology, cannot perform scans where the tip is perpendicular to the surface. To perform scans with the tip perpendicular to the surface, an RSP3 must be used.
Fixed Quill
Probing Support: REVO (RSP2)
Fixed Quill scans are used to measure circular features where an appropriate probe angle can be selected that places the scanning tip along the vector normal of the feature. The probe head's center of rotation is centered on the circular feature, normal to the feature axis. Using only head motion, the tip is placed in contact with the surface to be scanned, and the programmed scan path is followed using only head motion to acquire the scan data. The only CMM motion may be to move the probe along the feature axis to measure at different depths. This type of scan is valid for circular features only such as circle, cylinder, and cone.
This is much more efficient than 3-axis scans since only the mass of the head is being moved to follow the scan path.
5-Axis
5-Axis scans use both head motion and the CMM axes to follow a complex scan path. The tip is placed in contact with the surface to be scanned, and the programmed scan path is followed using various combinations of head and CMM motion to follow the scan path. The different types of paths are described in the various feature measurement articles where this type of scan is supported.
This is more efficient than 3-axis scans since much of the motion is executed by the head.
5-Axis Sweep
5-Axis sweep scans use both head motion and the CMM axes to follow a complex scan path. In a sweep scan, the CMM can follow a defined path while head motion is used to sweep the tip rapidly back and forth across the surface allowing a very large amount of planar/surface data to be acquired. The tip is placed in contact with the surface to be scanned, and the programmed scan path is followed using various combinations of head and CMM motion to follow the scan path.
