Important changes to Get Probe Assembly Operation for version 3.7 on I++ systems
Starting from CMM-Manager 3.7, Get Probe Assembly Operation(s) will use the probe name to retrieve the probe. The probe name will be saved to the project/program. Programs from previous versions of CMM-Manager will not have a probe name saved in the program. Instead, those programs will contain the probe index (0, 1... N, etc.). Legacy programs can still be opened and executed on a non I++ machine. However, programs need to be migrated to the latest version to Run on an I++ machine.
The I++ Migration command allows users to migrate legacy programs to the new version or file format. Users can specify a list of legacy projects and programs that need to be migrated. You should also specify the original probe assembly file associated with the legacy projects/programs. If all the probe assemblies used by legacy projects and programs exist on a single probe assembly file, a single batch run of the I++ Migration command is sufficient. If multiple Probe Assembly files are used for all programs, please repeat this migration procedure for Programs and respective Probe Assembly files.
We suggest creating a backup of all pre-3.7 Projects / Programs before migration; this migration process is irreversible similar to Program Mirror(ing)
1. From the Ribbon Bar, select Program Tab>Program Management Group>Option Button>I++ Migration.
2. The I++ Migrate Project/Program Files dialog pops up.
3. Locate the probe assembly file by clicking on the Browse button - Important: Specify the original probe assembly file associated with the legacy program(s) being migrated
4. Locate the project/program files that you intend to migrate by clicking on the Browse button.
5. Start the migration operation by clicking on the Execute button.
