Renishaw Controller / UCC Suite version support
The following table lists the supported controllers and the versions of the UCC Suite required for each.
The following UCC Suite versions are not supported:
5.6.x
5.7.0, 5.7.1
5.9.x
5.10.0
Windows 11 support begins with 5.9.0 however, as noted above, the first compatible version is 5.10.1
Information is current as of Jan 2026
Direct Connect 3.0/2.0 - does not support SP25 scanning, PH20, or Revo
Controller | UCC Suite | Notes |
UCC1 | N/A (Obsolete) |
UCClite | N/A (Obsolete) |
UCClite-2 | 4.7.0 --> 4.8.4 |
UCC2 | 4.7.0 --> 5.5.1 | Renishaw support for UCC2 ended with 5.5.1 |
UCC2-2 | 4.7.0 --> 5.5.1 | Renishaw support for UCC2-2 ended with 5.5.1 in |
UCC T3/Fusion | 4.7.0 --> 4.8.4 | Renishaw support for UCC T3/Fusion ended with 4.8.4 |
UCC T3 PLUS | 4.7.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
UCC T3-2 | 4.7.2 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
UCC S3 | 4.7.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
UCC T5 | 4.7.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
UCC MT5 | N/A |
UCC S5 | 5.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
I++ DME
| UCC T3 PLUS | 5.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
| UCC T3-2 | 5.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
| UCC S3 | 5.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
| UCC T5 | 5.0 --> 5.5.1, 5.7.2 --> 5.8.6, 5.10.1, 5.11.3 |
| UCC MT5 | N/A |
Related Articles
Renishaw - UCC Direct 3.0 (DCC)
UCC Direct 3.0 is an improved version of UCC Direct 2.0 driver and supports a wide variety of configurations running on a Renishaw UCC controller with tactile probing. UCC Direct 3.0 uses a sub-set of I++ commands via UCCserver and the ClientTool ...
Renishaw - Setup the UCCserver Client Tool Environment
Please ensure your UCC controller and UCC Suite version support Client Tool Environment. See UCC Direct 2.0 (DCC) - Controller / UCC Suite versions for compatibility. For legacy UCC Direct users upgrading to UCC Direct 2.0 Make a note the current ...
Renishaw - UCC T3 Plus (+) / S3 / T5 / I++ (DCC)
DCC Models: UCClite, UCClite2, UCC1, UCC2, Fusion, T3, T3+, T5, S3, S3+ Supported Probes: PH20, PH20+, Revo-2, PH10 and all other Renishaw indexable probes with digital probing. Supporting Probing: TP2, TP20, TP200, SP25, RSP2 & 3 (Revo) UCC Suite ...
Renishaw UCC Suite (Server) upgrade sequence
It may be necessary at times to upgrade UCC Suite from a very old version (4.4 for instance) to a more current release (ie: 5.8). Due to some required upgrades that occur during intermediate steps, Renishaw recommends upgrading in the following ...
Error - "[4999] Unable to establish a connection to the controller", "Controller communications failure"
This is not a CMM-Manager error message. It is a pass-through error message that comes from UCC Server and is displayed by CMM-Manager for the user. This message indicates that Renishaw UCC Server or the Renishaw UCC Driver cannot communicate to the ...
CMM-Manager YouTube Channel
