CMM-Manager supported probe change racks
Probe Rack Guides
ACR1
The Renishaw ACR1 tool change rack is used with Renishaw probing systems, which utilize the AutoJoint style tool connection system. The ACR1 rack requires additional components and wiring to the controller in order to control the locking and unlocking of the tools during a tool change.
ACR3
The Renishaw ACR3 tool change rack is used with Renishaw probing systems, which utilize the AutoJoint style tool connection system. The ACR3 Tool Changer performs the same function as the older style ACR1 rack, but the ACR3 is passive, meaning that no electrical power or control signals are used. The ACR3 is a module that mounts to the Renishaw Modular Rack System.
FCR25
The Renishaw FCR25 module/tip change rack is used with the Renishaw SP25 Analog Scanning Probe. SP25 probe modules can be changed with the rack as-is. With available insert adapters, any port can be made to accept SP25 Stylus modules or TP20 force modules. This makes the FCR25 a very versatile rack. The rack is also passive, meaning that no electrical power or signal connections to the control system are required.
Three versions are available. The FCR25-3L (shown) with 3 ports, the FCR25-6L with 6 ports, and an FCR25-3L without the mounting post for use with the Renishaw Modular Rack System.
MCR20
The Renishaw MCR20 tip change rack is used with the Renishaw TP20 Touch Trigger Probe system. The MCR20 rack is a passive system requiring no electrical power or signal connections to the control system.
SCR200
The Renishaw SCR200 tip change rack is used with the Renishaw TP200 Analog Touch Trigger Probe system. The SCR200 requires additional components to monitor various signals from the rack and control the inhibiting of the probe during tip changes.
