CMM-Manager | Installation - Mitutoyo - UD1 PCI
Mitutoyo - UD1 PCI (Manual)
Model: UD1 PCI Card
Install the driver for the UD1 PCI Card - Note: 32 and 64 bit OS supported with CMM-Manager 3.8+
Alert
Important note for UD1W.dll file - from install guide:
1. For CMM-Manager to communicate with the UD1 card, the following files are needed. Look for these files in the UD1 installation disk or in the installation folder of current software.
      UD1W.dll
      UD1W.ini (optional)
2. Copy the above files into...
      [32 bit OS]: %SystemRoot%\system32 directory.
      [64 bit OS]: %SystemRoot%\SysWoW64 directory"
Info
If you see error message from CMM-Manager on connection attempt stating "cannot find UD1W.dll file, then copy the files mentioned above to C:\Program Files (x86)\Common Files\Nikon\NMCmmServices folder instead. This seems to be typical for WIndows 10 64 bit systems.
Mitutoyo UD1 PCI card - plug-n-play withCMM-Manager
