When upgrading from a legacy version of Direct Connect or I++ to Direct Connect 2.0, it is recommended you review and update the acceleration parameters in UCC Server:
- Expand the Advanced tree: Machine | ClientToolEnvironment | Equipment | Tools | ClientTool | GoToPar | Accel and PtMeasPar | Accel
- Edit the Act and Def values and set them = to the Max value.
The same changes should be made to the 'UnDefTool' tool as well.
Note: The Double-Click to edit the values it a bit... touchy. You may have to try several times to get the timing just right.
