CMM-Manager failed to launch with the following error:
This error occurs often when CMM-Manager is launched remotely over RDP.
While most users may never encounter this issue, it is common for IT personnel to maintain the PC remotely. Sometimes, this maintenance may include upgrading and running CMM-Manager.
The workaround is to terminate the RDP session and launch CMM-manager directly at the PC.
Note that this issue affects other applications launched in the same manner.
See also:
- https://support.esri.com/en/technical-article/000020069
- https://support.esri.com/en/technical-article/000023067
