Launch CMM-Manager Program using External Command
It is possible to run another CMM-Manager Program from the External Command operation. This is useful if you'd like to create a simple launching program - i.e. main program that prompts user for next program, and then runs accordingly to user response. A similar work flow can be achieved using Shop Floor Launcher, however this method allows some unique functionality such as using Barcode scanner to specify Program.
In this example, a simple VB Script is used to display an InputBox() where user can specify Program number.
Most modern USB or wireless Barcode scanners can be setup to replace user Keyboard entry. See example here -
https://youtu.be/-AZtCto4RwE - while CMM-Manager InputBox() is open during program run, user simply scans barcode, contents of barcode are sent to CMM-Manager along with user defined characters such as [Tab} or [Enter] key. This method reduces the possibility of user keyboard entry errors.
The External Command command allows you to execute a DOS Prompt / Terminal style command(s) as a CMM-Manager program operation. This is useful in running external applications from within CMM-Manager and allows for the use of fixed or dynamic command arguments. Dynamic command arguments are allowed and can either be customer data entries or variables from a previous VB Script. In this case the Arguments for External Command are fixed and contain both the Program File Path / File Name as well the the "/r" parameter that let's CMM-Manager know to Run the specified program.
See the attached sample program. When run it will prompt user for input between 1-4 (again barcode scanner could provide this input) then executes Prog_1.comp, Prog_2.cmp, etc. based on user input.
Related Articles
VB Script - Getting Started
What can I do with VB Scripting? CMM-Manager VB Scripts run in line with program execution and can be used to perform loops and flow control, display custom messages, prompt user for input that then influences program execution - i.e. skip section of ...
VB Script - Global Variables
CMM-Manager's VB Script engine does not currently support Global Variables. Each time the program is run all variables are re-created / set based on current program execution. It is however possible to write data to an external location such as ...
VB Script - Create custom text / report file
With VB Scripting it is possible to read / write text files to / from the CMM-Manager program. This could be useful for reading data from an external source or for writing custom reports or sending data to a third party or even a machine tool. This ...
VB Script - Multi Piece Reporting
It's possible to generate custom text string(s) to be used in the User notes Report Operation. Thus, allowing the user to create a report output in any format they choose including for example a summary of diameter(s) from a bolt pattern as shown ...
VB Script - Extract High & Low Deviation from Cloud-to-CAD Report
When reporting Cloud-to-CAD it is possible to display the Min / Max / RMS / Profile / etc. however only the individual Point X, Y, Z, or 3D value(s) can be set to Variable using the GetReportInfo() VB command like this: MyVar = GetReportInfo( ...
CMM-Manager YouTube Channel
