Joystick Measurement is a hands-on, teach-mode technique where the operator drives the CMM probe directly to the workpiece using the machine's manual handbox or joystick. Rather than relying on pre-existing CAD models or mathematically defined coordinates, you manually guide the stylus to trigger touch points across the physical surface of a part. Once all required contact hits are registered, CMM-Manager automatically calculates the geometric feature and populates it directly into your Feature Database.
Depending on your project workflow, joystick measurements can serve as a one-time dimensional check or be recorded into the Program Database so the sequence can replay unattended under automated DCC (Direct Computer Control) motion.
When to Choose Joystick Measurement
Metrologists frequently refer to Joystick Measurement as the "No Print, No CAD" approach. It fills a critical operational gap where digital models or nominal blueprint dimensions are not readily available.
If you are inspecting a prototype, legacy tooling, or a one-off job without a 3D CAD model or nominal coordinate list, CAD Measure and Define Feature methods cannot be used. Joystick mode allows you to immediately begin taking measurements on the granite without waiting for engineering data.
It is also the ideal method for quick walk-up inspections. If a machinist needs a rapid verification of a single bore diameter, step height, or rough first-article feature, jogging the probe to take three or four manual hits takes only seconds and avoids the overhead of setting up a formal inspection program.
Finally, Joystick Measurement plays a foundational role in routine programming setups. Metrologists commonly use the joystick to establish an initial manua part alignment or rough datum reference frame on a raw workpiece. Once that initial alignment locates the physical part in machine space, the programmer can hand off the remainder of the inspection to automated DCC execution. It is also the primary operating method when running a fully manual, non-motorized CMM.
Executing a Joystick Measurement
Entering Joystick Mode
To begin, navigate to the Features tab located on the primary Ribbon Bar. In the Teach section on the left-hand side, click the Joystick option. If you intend to save these moves into a program routine for automatic playback later, confirm that the system is operating in Teach-On Mode, indicated by the green apple icon and a blue graphics background.
Selecting Your Feature Type
Click the blue icon corresponding to the geometry you wish to measure, such as a Point, Line, Circle, Plane, or Cylinder.
Configuring the Measurement Preference
Selecting a feature opens the Measurement Counter window. This utility manages how the software calculates your feature:
- Feature Naming: You can assign a custom name to the feature by entering the text and selecting the update option.
- Hit Count: You can adjust the required number of physical contact points using the on-screen arrow counters or by keying in a specific quantity.
- Probe Compensation and Projection: For two-dimensional features like lines and circles, ensure that probe radius compensation is active and verify that the appropriate projection plane is designated so the software compensates the stylus radius in the correct direction.
- Manual vs. Program Mode: Select Manual if you simply need a quick, one-off measurement that does not need to be saved into the part program. Select Program if you want CMM-Manager to record the routine into your program database for automated DCC execution later.
- DCC Re-Measure Option: If you select Program mode, you can enable the DCC Re-Measure option. This allows you to roughly locate and measure the feature using the joystick, after which the CMM automatically takes over, re-approaching and measuring the feature under CNC control with uniform touch speed and pre-travel consistency for maximum accuracy.
Teaching Collision-Free Transit Paths with "Add Move"
*Joystick Mode does not rely on a CAD model. The CAD model is displayed for visualization purposes only
When Program Mode is active, CMM-Manager records your motion into an automated DCC sequence. However, unlike CAD-guided routines that automatically calculate collision-free trajectories around solid surfaces, Joystick mode relies on the programmer to establish the approach path. Before taking hits on the feature—especially when navigating around fixtures, clamps, ribs, or deep internal pockets—you should jog the probe along a safe path to the feature. At each safe waypoint or clearance position, click the Add Move button inside the Measurement Counter window. CMM-Manager records these intermediate 3D coordinates into the routine, ensuring that during subsequent automated playback the machine follows the exact taught, collision-free transit route directly into the feature rather than making a straight-line move that could strike the part.
Taking the Surface Points
Once the probe is safely positioned at the feature, jog the probe using your handbox to take the required contact points on the physical part. The large on-screen digital display counts down with each registered contact hit, guiding you until the counter reaches zero.
Defining Exit Clearance Moves and Completing the Feature
Just as with the approach path, exiting the feature requires safe transit planning in Program Mode. When prompted to establish an exit trajectory after the final contact hit, jog the probe clear of the feature to a safe intermediate position or clearance height above all clamps and part geometry, then click Add Move to capture the retract path. Finally, confirm the feature dialog to calculate the nominals and actuals, store the constructed geometry in the Feature Database, and commit the complete motion and measurement block to your inspection routine.
Correcting Estimated Nominals for Reporting
Because Joystick Measurement is performed without an underlying 3D CAD model, CMM-Manager has no digital reference to determine what the feature's dimensions were intended to be. As a result, the software automatically estimates the feature's nominal values based on the physical actuals you just measured.
This means that immediately after measurement, the reported nominal size and location will match your manufactured part's imperfections rather than the engineering design intent. If you leave these values unedited, any subsequent inspection report will display zero deviations or inaccurate tolerance evaluations.
Before publishing inspection reports or evaluating GD&T callouts:
- Open the Feature Properties from the Feature Database.
- Manually overwrite the estimated nominal coordinates, size, and orientation with the true basic dimensions and design values specified on your engineering drawing or blueprint.
