How to Replace a CAD Model in CMM-Manager Program
In some cases, an existing CAD model may need to be replaced due to a revision change or other design updates. Rather than creating a new program from scratch, it is generally more efficient to replace the existing CAD model and re-teach only the features, measurement paths, and reports affected by the revision. This approach minimizes redundant programming and preserves the existing inspection program.
This article provides general guidelines for replacing a CAD model in an existing CMM-Manager program.
Deleting the Existing CAD Model
The existing CAD model can be removed by clicking the Remove CAD icon under the Import/Export tab in the Ribbon Bar.
CMM-Manager will prevent the CAD model from being deleted if the program contains a function that requires the CAD model during program execution. The following commands may depend on the CAD model:
  1. Cloud-to-CAD Alignment
  2. Cloud-to-Curve Alignment
  3. CAD Alignment
  4. Cloud-to-CAD Deviation Report
  5. Cloud-to-Curve Deviation Report
  6. GD&T Profile Report (when a cloud is used)
If any of these commands are included in the program, refer to the final chapter of this article (Handling CAD-dependent Commands) for detailed instructions on handling these special cases.
Importing and Synchronizing the New Model
Import the new CAD file using the Import/Export tab in the Ribbon Bar.
Ensure that the location and orientation of the CAD reference frame match those of the previous CAD model. If the reference frame has changed, use the appropriate commands under the Import/Export tab to update it to ensure the consistency.
In the Program Database, select the program line where the initial alignment has been completed. Then, execute the Sync CAD function. After synchronization, existing features should align with the new CAD model, provided their nominal locations have not changed as a result of the revision.
Updating Nominals and Measurement Paths
The nominal values and measurement path for a feature can be updated from the Nominal tab in the feature measurement window.
The easiest way to update the nominal information is to use the Re-Pick CAD function. This allows the feature data to be extracted directly from the updated CAD model. Ensure to press the Apply button once the CAD entity is selected. Alternatively, new values can be manually entered.
After updating a feature's nominal values, any associated reports should also be updated to reflect the new nominal information.
To update a report:
  1. Right-click the report command in the Program Database.
  2. Select Update Report.
  3. Enable the Update Nominal option.
This section provides guidance on how to manage the CAD-dependent functions described earlier in this article.
Cloud-to-CAD/Cloud-to-Curve Alignments and Deviation Reports
First, ensure that the CAD reference frame of the new model has the same location and orientation as the existing model.
Open the existing program and hide the current CAD model using the CAD Editor under the Display tab in the Ribbon Bar.
Import the new CAD model. Because the reference frames are identical, the new model should be positioned correctly.
For each Cloud-to-CAD or Cloud-to-Curve command in the program:
  1. Double-click the command to open its properties.
  2. Under the CAD Surface\Curve List, delete all surfaces and curves associated with the old model.
  3. Re-teach the command by selecting the required surfaces and curves from the new CAD model.
After updating the commands, open the Layers tab in the CAD Editor and delete any layers associated with the old CAD model.
GD&T Profile Report with Clouds
A similar procedure can be used to update a GD&T Profile Report that uses clouds.
Delete the existing CAD references associated with the old model and re-teach the required CAD surfaces using the new model. Ensure that the appropriate cloud is still associated with the report after the CAD references have been updated.
CAD Alignment
The existing CAD Alignment command must be deleted and re-taught after the new CAD model has been imported.
