Use password (w/o quotes) “packers” to unzip files to C:\PEWINPRO.
Run C:\PEWINPRO\Install1.exe.
Select PEWIN32 Pro.
Use serial no (w/o quotes) “2026914” to authenticate.
Install PEWIN32 Pro software Service Pack - PewinProSP30.exe
Use password (w/o quotes) “packers” to unzip files to C:\deltatau.
Run C:\deltatau\disk1\Setup.exe.
When the installation is complete, re-boot your computer.
Install the PEWIN 64 bit drivers if installing on a 64 bit computer
For serial connection - DT64bitDrivers.zip
The PMAC device won't show up in Device Manager as it is a serial connection. You will need to have a COM port available on the computer.
For USB connection - Windows 8.1 Drivers.zip
If you plug in the cable and the driver is not present, the PMAC device shows up in Device Manager under Other Devices:
After the driver is installed properly, the PMAC device shows up in Device Manager under Motion Controllers:
Register PMAC Device
Run PEWIN32Pro as administrator
Select menu Setup > General Setup and Options
In the General Setup and Options window, under the Default Device tab, click the select button
In the PMAC Devices window, highlight PMAC 01 - NA first and then click the Insert button
Click on the COM port that the device is connected to. There could be several to choose from. Highlight it, and then click OK. (If a PC104 controller, it could be a USB device).
Click OK to accept this. In most cases, there is no need to change baud rate or parity.
To verify if all was done correctly, and the correct Com Port was selected, click on the Test button. The software will test the communication settings and let you know if the PMAC card was detected. If it is not detected, use the Remove button to remove the device and try inserting again with a different Com Port.
